ScanGauge II problems
Old Sep 1, 2006 | 07:27 PM
jmorton10's Avatar
Default Re: ScanGauge II problems
I talked to Ron for quite a while today, he's a real nice guy.
Apparently, these problems we are having ONLY occur with Hybrid Escapes.
My original SG still works perfectly on my FEH but he said that has a totally different chip design.
~John
Old Sep 4, 2006 | 09:27 PM
Wbruff's Avatar
Technology Enthusiast
Just an update here on my 2nd ScanguageII. Except for the first day I have not had any problems at all (knock on wood). After the first time it locked up I tried something. I went to the settings for mode and told the unit that it was hooked up to a CANSF rather than Automatic. I don't know if that is what allegedly fixed it or not but it's been 4 days now. John, have you gotten your replacement unit yet?
Old Sep 5, 2006 | 01:37 AM
GaryG's Avatar
Hi Bill
That very well may have been your problem. I don't recall auto as a setting on my SG 1, but I've always had mine set for CANSF and the highest speed setting. Let's hope that was the only problem. If you remember, many did not know the Hybrid setting was under "type of fuel" and that also made the SG mess up because they set it for "gas".
GaryG
Old Sep 5, 2006 | 03:47 AM
jmorton10's Avatar
Mine is shipping out today.
~John
Old Sep 5, 2006 | 06:49 AM
GaryG's Avatar
Hi John
Is it possible you may have set your SG 11 to automatic also? The setup is very important and can make the SG malfunction if not setup properly.
GaryG
Old Sep 5, 2006 | 07:53 AM
jmorton10's Avatar
Originally Posted by GaryG
Hi John
GaryG
I thought when I read this that there is the problem as I don't ever remember changing that setting. I just went out & checked it however & it was set to CANSF.
~John
Old Sep 5, 2006 | 11:08 AM
  #27
Wbruff's Avatar
I beleive that unless you force it to cansf by hitting the force button it will still be automatically seeking everytime it turns on. That being the problem since it tries to negotiate a connection sometimes when you simply open the car door and the brakes go thru their charge up routine.. The lock up used to always occur at that time at least in my case. Just a thought
Old Sep 5, 2006 | 12:02 PM
  #28
jmorton10's Avatar
That is the only time mine locks up also. How do you "force" the setting??
When I checked mine & it was already set to CANSF, I didn't see anything to change??
~John
Old Sep 5, 2006 | 03:09 PM
  #29
Wbruff's Avatar
On the same screen that you selected CANSF the bottom right of the screen says force, on mine at least.
Old Sep 20, 2006 | 03:56 PM
  #30
GaryG's Avatar
Hi Bill and John
Can you give us an update on newer SG11 replacement?
GaryG
