Replacing 12v battery
Sorry for asking a dummy question. I have a 2006 Ford Escape hybrid. The 12v battery is needing to be replaced. The last replacement was at the Ford dealership a few years ago but with Covid the wait time Now is over a week. I have a battery set aside at Ford. I’ve changed batteries years ago in my old Honda Civic and feel I should do this myself but wondering if there is something I need to know about replacing a low voltage battery in a hybrid vs in a non-hybrid. I’m assuming it is the same but not sure and nothing in the owner’s manual was helpful.
Cheers.
Cheers.
Nothing special because it's a hybrid.
Disconnect negative first.
Disconnect positive.
Loosen clamping mechanism
remove battery
Install new battery.
Tighten clamping mechanism.
Connect positive first
Connect negative.
remove battery
Connect negative.
Amazing, I had exactly the same question. As I'm going over the maintenance records for my new-to-me 2010 FEH, I found that the existing 12v battery was replaced 4 years ago. Right now it's doing fine, no problems, but I expect to have to replace it sooner than later.
Glad to hear it's just like every other car with no strangeness because of the hybrid system.
Travis Beck
Nov 6, 2019 08:12 PM
Orient Express
Jul 23, 2011 09:38 AM
cmcd
Oct 27, 2008 03:59 PM
