Rear spoiler
Old Apr 9, 2006 | 12:46 PM
dbennettya's Avatar
Question Rear spoiler
Hi,
Did a search and couldn't find an answer. I'm looking for feedback on the rear spoiler Ford 1L8Z-78500K16-AAC for FEH. Does anyone have this installed and how does it work? Any down sides to the installation? What did the dealer or body shop charge to install and paint it?
Thanks, Don
Old Apr 10, 2006 | 01:34 AM
nightracerx's Avatar
Wink Re: Rear spoiler
Originally Posted by dbennettya
Hi,
Thanks, Don
The spoiler is primed, which means it doesn't come with color. You can order it and ask some bodyshop to paint it, it usually costs around $100-$150 to paint, just make sure it matches your car's color and come with clearcoat.
For the installation part, I recommend you take it to the dealer and ask them to install it for you, I think(not sure) you need to drill holes on the roof and align them correctly.
For the look part, it makes your car look sportier. I highly doubt it improves air drag and handling during high speed.
Old Apr 10, 2006 | 08:03 PM
AZMerf's Avatar
Default Re: Rear spoiler
Supposedly, aren't they supposed to keep the rear window cleaner?
Old Apr 14, 2006 | 12:24 PM
dbennettya's Avatar
Hi all,
Thanks for the replies, still looking for someone that actually installed one and can determine if it is worth the risk of long term corrosion from drilling holes to mount it? Versus the benefits it provides.
Don
Old Apr 22, 2006 | 12:21 PM
rihavo's Avatar
I haven't had one installed on my 05 FEH, but I did have one installed on my '99 Dodge Durango (the vehicle I traded in for my FEH.) Chrysler offered two different models depending on the year. The one I had was bolted to the rear lift gate. I was told that this model was the better of the two models. It did help to keep the rear window cleaner and it also helped minimize the amount of water being sprayed up from the back tires when driving. The only thing I didn't like was you had to watch out when you took if to a car wash. if you went to know with the "brushes" you ran the risk of it being ripped off your vehicle. I would presume the same would be true with the one for the FEH. If it is installed correctly, you shouldn't have to worry about corrosion. If it bolts the the vehicle, the kit should come with caps or something to help prevent the corrosion.
I liked it and I felt it was worth it. However I don't like the way the rear air deflector looks for the FEH.
Good Luck.
Rich
nicst47
Jul 31, 2009 07:18 AM
Randyman
Apr 14, 2008 04:12 PM
elsifer
Feb 23, 2007 11:24 AM
joystix2
Sep 25, 2006 05:15 PM
rjivey
Sep 18, 2006 11:49 AM
