Rattles - fixed one, need help on 2nd
Old Sep 15, 2009 | 01:17 PM
travelover's Avatar
Feral Engineer
Default Rattles - fixed one, need help on 2nd UPDATE
UPDATE
Just got back from the dealer and the clunk rattle was caused by the link on the front stabilizer bar.
I Googled this issue and it seems this is a very common problem on all Escapes (not just FEH). It felt kinda loose when I checked it, so I was pretty sure going in that this was the problem.
If you want to check this on your own Escape, I think the tire needs to be on the ground, other wise the link is loaded and you will not feel the slop in the end joints.
Old Sep 15, 2009 | 04:09 PM
econoline's Avatar
Default Re: Rattles - fixed one, need help on 2nd UPDATE
Originally Posted by travelover
UPDATE
What is the fix for this?
Old Sep 20, 2009 | 05:32 PM
travelover's Avatar
Feral Engineer
Replace the sway bar link(s). It is a plastic rod about 6" long with a ball joint on each end. It is an easy DIY job and the part is about $20, but since I was still under warranty, I had it done.
Old Sep 21, 2009 | 06:25 PM
kpdandjad's Avatar
I have a 2008 FEH 2WD with 34,000 miles. I just had it at the Dealer for state inspection and they said the front stabilizers were worn out and replaced them under warranty.
Davis_Walker
Oct 7, 2014 04:48 PM
houseofcharm
Oct 14, 2009 07:18 PM
Jason
Website Questions & Input
May 26, 2005 12:42 AM
Jason
Our Announcements
Sep 9, 2004 08:26 AM
