Re: P1A10, Another "Stop Safely Now" Thread
1 Attachment(s)
Took me forever to get forscan. Here is the log:
===PCM DTC P1000:00-2B=== Code: P1000 - OBD Systems Readiness Test Not Complete Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Powertrain Control Module ===END PCM DTC P1000:00-2B=== ===PCM DTC U0111:00-2B=== Code: U0111 - Lost Communication With Battery Energy Control Module A Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Powertrain Control Module ===END PCM DTC U0111:00-2B=== ===OBDII DTC None=== Successful DTC reading, no error codes found Module: On Board Diagnostic II ===END OBDII DTC None=== ===ABS DTC U3003:16-68=== Code: U3003 - Battery Voltage Additional Fault Symptom: - Circuit Voltage Below Threshold Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC - Test not complete Module: Antilock braking system Freeze Frame : -OUTTMP: -14 °C - External Temperature From Sensor -ABS: Inactive - ABS -AYC: Inactive - AYC -BTCS: Inactive - BTCS -201D -HDC: Inactive - HDC -RSC: Inactive - RSC -BTC: Inactive - BTC -VAC_BST_ST: Inactive - Active Vacuum Booster State -BST_REL_SW: Inactive - Booster Release Switch State -HYD_PMP_ST: Active - Hydraulic Pump State -VPWR_ABS: 10.00 Volt - Module supply voltage -VSS: 0.0 km/h - Vehicle Speed ===END ABS DTC U3003:16-68=== ===RCM DTC None=== Successful DTC reading, no error codes found Module: Restraint Control Module ===END RCM DTC None=== ===TCM DTC P0562-FF=== Code: P0562 - System Voltage Low Module: Transmission Control Module ===END TCM DTC P0562-FF=== ===TCM DTC P0A0A-FF=== Code: P0A0A - High Voltage System Inter-lock Circuit Module: Transmission Control Module ===END TCM DTC P0A0A-FF=== ===APIM DTC B1136-60=== Code: B1136 - Audio Steering Wheel Switch 2 Circuit Failure Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Accessory Protocol Interface Module ===END APIM DTC B1136-60=== ===OCS DTC None=== Successful DTC reading, no error codes found Module: Occupant Classification System Module ===END OCS DTC None=== ===4X4M DTC None=== Successful DTC reading, no error codes found Module: 4X4 Control Module ===END 4X4M DTC None=== ===PSCM DTC None=== Successful DTC reading, no error codes found Module: Power Steering Control Module ===END PSCM DTC None=== ===IC DTC B1318-20=== Code: B1318 - Battery voltage Low Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Instrument Cluster Diagnostic Trouble Code details Battery voltage Low Possible causes are: Battery voltage line - open or short Blown EPS fuse Poor battery condition EPS CM malfunction Poor connection of each connector Control Module ===END IC DTC B1318-20=== ===IC DTC U2472-20=== Code: U2472 - Unexpected Ignition State Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Instrument Cluster ===END IC DTC U2472-20=== ===IC DTC U2023-20=== Code: U2023 - Fault Received from External Node Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Instrument Cluster Diagnostic Trouble Code details Fault Received from External Node This DTC may be caused by : Short circuit on the CAN line. Open circuit on the CAN line. There is a time out between two modules on the CAN bus There is Interference on the CAN bus There may be other modules on the CAN communication data line that are not communicating and are timing out. Note: DTCs that start with 'U' are faults which occur during module-to-module communication. Modules should never be replaced based only on a 'U' code. These codes do not always indicate a problem, and can be caused by normal diagnostic functions, carried out on the vehicle. ===END IC DTC U2023-20=== ===IC DTC B1600-20=== Code: B1600 - At some time since last clear the ignition was switched on without any key code being read. Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Instrument Cluster Diagnostic Trouble Code details At some time since last clear the ignition was switched on without any key code being read. --- Possible Causes -------- PATS ignition key transponder signal not received NO transponder signal detected during start -Suspect Ignition key PATS antenna or wiring Module ===END IC DTC B1600-20=== ===IC DTC U2511-60=== Code: U2511 - CAN communication bus fault Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Instrument Cluster ===END IC DTC U2511-60=== ===IC DTC U0111-60=== Code: U0111 - Lost Communication With Battery Energy Control Module A Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Instrument Cluster ===END IC DTC U0111-60=== ===FDIM DTC None=== Successful DTC reading, no error codes found Module: Front Display Interface Module ===END FDIM DTC None=== ===SDARS DTC B1031-60=== Code: B1031 - SDARS Satellite Antenna Open Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Satellite Digital Audio Receiver System ===END SDARS DTC B1031-60=== ===SDARS DTC U0184-20=== Code: U0184 - Lost Communication With Radio Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Satellite Digital Audio Receiver System ===END SDARS DTC U0184-20=== ===SDARS DTC U0255-60=== Code: U0255 - Lost Communication With Front Controls Interface Module Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Satellite Digital Audio Receiver System ===END SDARS DTC U0255-60=== ===HVAC DTC B12B8-60=== Code: B12B8 - Driver Blend Door Actuator, Slow or Door Obstructed Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Heating Ventilation Air Conditioning ===END HVAC DTC B12B8-60=== ===HVAC DTC B12A5-60=== Code: B12A5 - Mode Door Actuator, Feedback Circuit Open or Shorted to Battery Voltage Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Heating Ventilation Air Conditioning ===END HVAC DTC B12A5-60=== ===HVAC DTC B12A6-20=== Code: B12A6 - Mode Door Actuator, Feedback Circuit Open or Shorted to Battery Voltage Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Heating Ventilation Air Conditioning ===END HVAC DTC B12A6-20=== ===HVAC DTC B298A-60=== Code: B298A - Mode Door Actuator Drive Circuit(s) Open Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Heating Ventilation Air Conditioning ===END HVAC DTC B298A-60=== ===GEM/SJB DTC None=== Successful DTC reading, no error codes found Module: Generic Electronic Module / Smart Junction Box ===END GEM/SJB DTC None=== |
What is the 12V battery voltage at the terminals?
It's fully charged. I put a trickle charger on the 12V and it is less than 4 months old. Took it to autozone about two weeks ago and it came back good.
You have multiple systems reporting low 12V.
Key on, engine off. Measure voltage across 12V battery terminals. |
(Post 271516)
Key on, engine off. Measure voltage across 12V battery terminals. https://cimg4.ibsrv.net/gimg/www.gre...bc4c7ce9a7.jpg |
Both terminals are disconnected. Need battery voltage with Key on, engine off where some load is being applied to the battery.
(Post 271521)
https://cimg3.ibsrv.net/gimg/www.gre...362fc6c7d8.jpg |
Okay, that confirms the battery can actually deliver a current and hold a voltage.
Now, disconnect the two terminals and short them together for 10 minutes. Ensure neither contact either battery terminal. This wipes every thing from every computer. Once complete, reconnect 12V battery. Key on- engine off. Re-run DTC check. |
(Post 271526)
Now, disconnect the two terminals and short them together for 10 minutes. Ensure neither contact either battery terminal. This wipes every thing from every computer. Once complete, reconnect 12V battery. Key on- engine off. Re-run DTC check. Shorted the terminals for 10 mins. Key on, engine off. DTCS: ===PCM DTC P1000:00-2B=== Code: P1000 - OBD Systems Readiness Test Not Complete Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Powertrain Control Module ===END PCM DTC P1000:00-2B=== ===PCM DTC P1A14:00-2B=== Code: P1A14 - Hybrid Powertrain Control Module - Transmission Disabled Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Powertrain Control Module ===END PCM DTC P1A14:00-2B=== ===PCM DTC P2450:00-E8=== Code: P2450 - EVAP System Switching Valve Performance/Stuck Open Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is On for this DTC - Test not complete Module: Powertrain Control Module ===END PCM DTC P2450:00-E8=== ===PCM DTC U0111:00-2B=== Code: U0111 - Lost Communication With Battery Energy Control Module A Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Powertrain Control Module ===END PCM DTC U0111:00-2B=== ===OBDII DTC P2450-C=== Code: P2450 - EVAP System Switching Valve Performance/Stuck Open Status: - Confirmed - malfunction is confirmed Module: On Board Diagnostic II ===END OBDII DTC P2450-C=== ===ABS DTC U3003:16-68=== Code: U3003 - Battery Voltage Additional Fault Symptom: - Circuit Voltage Below Threshold Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC - Test not complete Module: Antilock braking system Freeze Frame : -OUTTMP: -14 °C - External Temperature From Sensor -ABS: Inactive - ABS -AYC: Inactive - AYC -BTCS: Inactive - BTCS -201D -HDC: Inactive - HDC -RSC: Inactive - RSC -BTC: Inactive - BTC -VAC_BST_ST: Inactive - Active Vacuum Booster State -BST_REL_SW: Inactive - Booster Release Switch State -HYD_PMP_ST: Active - Hydraulic Pump State -VPWR_ABS: 10.00 Volt - Module supply voltage -VSS: 0.0 km/h - Vehicle Speed ===END ABS DTC U3003:16-68=== ===RCM DTC None=== Successful DTC reading, no error codes found Module: Restraint Control Module ===END RCM DTC None=== ===TCM DTC P0562-FF=== Code: P0562 - System Voltage Low Module: Transmission Control Module ===END TCM DTC P0562-FF=== ===TCM DTC P0A0A-FF=== Code: P0A0A - High Voltage System Inter-lock Circuit Module: Transmission Control Module ===END TCM DTC P0A0A-FF=== ===APIM DTC B1318-20=== Code: B1318 - Battery voltage Low Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Accessory Protocol Interface Module Diagnostic Trouble Code details Battery Voltage Too Low --- Possible Causes -------- - Battery Voltage below 9.6volts -Suspect Battery state of charge Charging system ===END APIM DTC B1318-20=== ===APIM DTC B1136-60=== Code: B1136 - Audio Steering Wheel Switch 2 Circuit Failure Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Accessory Protocol Interface Module ===END APIM DTC B1136-60=== ===OCS DTC None=== Successful DTC reading, no error codes found Module: Occupant Classification System Module ===END OCS DTC None=== ===4X4M DTC None=== Successful DTC reading, no error codes found Module: 4X4 Control Module ===END 4X4M DTC None=== ===PSCM DTC None=== Successful DTC reading, no error codes found Module: Power Steering Control Module ===END PSCM DTC None=== ===IC DTC B1318-20=== Code: B1318 - Battery voltage Low Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Instrument Cluster Diagnostic Trouble Code details Battery voltage Low Possible causes are: Battery voltage line - open or short Blown EPS fuse Poor battery condition EPS CM malfunction Poor connection of each connector Control Module ===END IC DTC B1318-20=== ===IC DTC U2472-20=== Code: U2472 - Unexpected Ignition State Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Instrument Cluster ===END IC DTC U2472-20=== ===IC DTC U2023-60=== Code: U2023 - Fault Received from External Node Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Instrument Cluster Diagnostic Trouble Code details Fault Received from External Node This DTC may be caused by : Short circuit on the CAN line. Open circuit on the CAN line. There is a time out between two modules on the CAN bus There is Interference on the CAN bus There may be other modules on the CAN communication data line that are not communicating and are timing out. Note: DTCs that start with 'U' are faults which occur during module-to-module communication. Modules should never be replaced based only on a 'U' code. These codes do not always indicate a problem, and can be caused by normal diagnostic functions, carried out on the vehicle. ===END IC DTC U2023-60=== ===IC DTC B1600-20=== Code: B1600 - At some time since last clear the ignition was switched on without any key code being read. Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Instrument Cluster Diagnostic Trouble Code details At some time since last clear the ignition was switched on without any key code being read. --- Possible Causes -------- PATS ignition key transponder signal not received NO transponder signal detected during start -Suspect Ignition key PATS antenna or wiring Module ===END IC DTC B1600-20=== ===IC DTC U2511-60=== Code: U2511 - CAN communication bus fault Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Instrument Cluster ===END IC DTC U2511-60=== ===IC DTC U0111-60=== Code: U0111 - Lost Communication With Battery Energy Control Module A Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Instrument Cluster ===END IC DTC U0111-60=== ===FDIM DTC B1318-20=== Code: B1318 - Battery voltage Low Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Front Display Interface Module Diagnostic Trouble Code details Battery Voltage Too Low --- Possible Causes -------- - Battery Voltage below 9.6volts -Suspect Battery state of charge Charging system ===END FDIM DTC B1318-20=== ===SDARS DTC B1031-60=== Code: B1031 - SDARS Satellite Antenna Open Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Satellite Digital Audio Receiver System ===END SDARS DTC B1031-60=== ===SDARS DTC B1318-20=== Code: B1318 - Battery voltage Low Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Satellite Digital Audio Receiver System Diagnostic Trouble Code details Battery Voltage Too Low --- Possible Causes -------- - Battery Voltage below 9.6volts -Suspect Battery state of charge Charging system ===END SDARS DTC B1318-20=== ===SDARS DTC U0184-20=== Code: U0184 - Lost Communication With Radio Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Satellite Digital Audio Receiver System ===END SDARS DTC U0184-20=== ===SDARS DTC U0255-60=== Code: U0255 - Lost Communication With Front Controls Interface Module Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Satellite Digital Audio Receiver System ===END SDARS DTC U0255-60=== ===HVAC DTC B12B8-60=== Code: B12B8 - Driver Blend Door Actuator, Slow or Door Obstructed Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Heating Ventilation Air Conditioning ===END HVAC DTC B12B8-60=== ===HVAC DTC B12A5-60=== Code: B12A5 - Mode Door Actuator, Feedback Circuit Open or Shorted to Battery Voltage Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Heating Ventilation Air Conditioning ===END HVAC DTC B12A5-60=== ===HVAC DTC B12A6-20=== Code: B12A6 - Mode Door Actuator, Feedback Circuit Open or Shorted to Battery Voltage Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Heating Ventilation Air Conditioning ===END HVAC DTC B12A6-20=== ===HVAC DTC B298A-60=== Code: B298A - Mode Door Actuator Drive Circuit(s) Open Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Heating Ventilation Air Conditioning ===END HVAC DTC B298A-60=== ===GEM/SJB DTC U0155-B0=== Code: U0155 - Lost Communication With The Instrument Panel Cluster Control Module Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is On for this DTC - Test not complete Module: Generic Electronic Module / Smart Junction Box ===END GEM/SJB DTC U0155-B0=== ===GEM/SJB DTC B1318-20=== Code: B1318 - Battery voltage Low Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Generic Electronic Module / Smart Junction Box Diagnostic Trouble Code details Battery Voltage Too Low --- Possible Causes -------- - Battery Voltage below 9.6volts -Suspect Battery state of charge Charging system ===END GEM/SJB DTC B1318-20=== |
I went completely cross-eyed halfway through that. It looks like it retained many prior codes as suggested by the numerous "not present at time of request".
Go into the DTC tab and clear the codes. re-check codes. |
