P0AA7 Hybrid Battery Voltage Isolation Sensor Circuit
Old Feb 9, 2021 | 11:36 AM
accent2010's Avatar
Default P0AA7 Hybrid Battery Voltage Isolation Sensor Circuit
Just got another 09 Escape. It runs fine but it has the P0AA7 wrench code too. Don't want to replace the battery this time. Any idea where the sensor or circuit located?
Old Feb 11, 2021 | 12:13 PM
Default Re: P0AA7 Hybrid Battery Voltage Isolation Sensor Circuit
This is that fun one again, where the recommended course of action is to:
1) Clear the codes
and if the code repeats...
2) Replace the HVTB.
Now, here's the interesting thing: In the 2011 Fusion, Milan, MKZ, Fusion Hybrid, Milan Hybrid, MKZ Hybrid Workshop Manual, instead of recommending replacement of the entire HVTB, they recommend replacing the Battery Pack Sensor Module (BPSM).
http://www.nicksmustangranch.com/Ser...l/sbse3009.htm
This code has to be generated by a similar module that is not named on the FEH. Would that be inside the BCM? You've already shot this bug before by replacing the BCM. Maybe it will work here, maybe not.
I can't find anything that shows where the exact circuit is that causes this code to be thrown. The code itself refers to the system making sure that the HV system is totally isolated from the rest of the vehicle.
How to troubleshoot it? There's a pretty good article here - at least in explaining what the code means. Diagnosing it and pinpointing the loss of isolation is another story.
https://www.vehicleservicepros.com/s...-fault-systems
accent2010
May 8, 2022 06:45 PM
Ryan2006HCH
Sep 25, 2021 09:33 AM
accent2010
Ford Motor Company
Jun 20, 2020 01:14 AM
ukrkoz
Sep 3, 2012 02:45 PM
kapo2004HCH
Oct 22, 2010 06:30 PM
