outside mirror ??
Old Dec 31, 2008 | 11:24 PM
Lone Ranger's Avatar
Default outside mirror ??
Does the Hybrid Escape have the wiring running for the outside rear view mirrors to be heated? I figure that if this option is available on other Escape models the wiring harness would be there just waiting to hook up.
Old Dec 31, 2008 | 11:54 PM
TeeSter's Avatar
Default Re: outside mirror ??
I have an '06 WITH heated Mirrors.... however don't count on the wiring harness being there without checking. They cut costs to the bone.. and a $1 on a wiring harness having an extra connection might not sound like much... but if you are building thousands of them....
Old Jan 1, 2009 | 12:18 AM
Ford wired the outside mirrors into the rear window defroster. To do what you want to do, you have to purchased two new outside mirrors and then purchase/obtain a new wiring harness. Labor cost are extra. I actually purchased two new outside heated sideview mirrors to do what you wanted. After I took off the inside door panel and got a look at the wiring harness-heated and non-heated mirrors are different--I realized I needed some help. My local dealership wasn't keen on performing this option so I put the "job" on the back burner. You will need to obtain a Ford OEM wiring book to help you with this proceedure.
Old Jan 1, 2009 | 09:56 AM
DesertDog's Avatar
I replaced the door wiring harnesses when I added a factory nav unit to my FEH and added the door tweeters. To add the heated mirrors, the part numbers for the door harnesses are:
Driver's door: 6L8Z 14631 HA
Passenger: 6L8Z 14630 HA
They list for $60.42 and $46.50, but can be had online for $43 and $33. It is a little tedious to replace them, but not that bad for an average DIYer.
Old Jan 1, 2009 | 09:59 AM
I bought a stock 07, what the dealer has on his lot. The car came from Iowa, which explains why there was no EBH on it, which I subsequently bought and installed. I also bought a compass/temperature/auto tint inside mirror and installed. I have had outside heated mirrors and I find them to be super helpful here in the winter. So I thought Ford might just wire all the vehicles the same and then just add options to the standard wiring harness as customers add options. I have an 03 Honda Goldwing motorcycle and there is a pigtail connection for options throughout the bike's wiring harness.
Old Jan 1, 2009 | 06:19 PM
Thanks Carl for the reply. I will have to look at this in the near future.
I posted today on your latest AWD scanguage coding and it measures friction braking.
Fun Times
10
Apr 10, 2012 06:49 PM
JOE540CI
Nov 20, 2006 09:31 PM
nomorebenz
Toyota Highlander Hybrid
Aug 3, 2006 04:00 PM
Dale B
Apr 10, 2005 10:03 AM
