Not good
Old Dec 17, 2006 | 08:03 PM
Duc's Avatar
Duc
Stock Sucks
Default Not good
I haven't owned a Ford in 10 years and after 700 miles my new FEH is headed to the shop. Now I know things happen and new cars can have problems but I have never owned a new car ever that has had to go in the shop at all more less after 700 miles.
It is a LOUD squeal/drag noise coming from the drivers side rear wheel (wife hung out of the back door while I was driving to find the source), doesn't increase or decrease when I brake but is extremely LOUD. Wife said she heard the wheel over 200 miles ago but forgot to tell me so tech it had problems at 450ish miles.
Oh and one of my rubber vibration tiddies for the hatch is missing, not a big deal but I hope it is not a sign of things to come.
Clif
Old Dec 18, 2006 | 04:16 AM
PML's Avatar
PML
Default Re: Not good
I have the same sound - like a wheel bearing - and applying the brakes does not send it away - it usually happens in turns - and comes and goes- like something is rubbing against a wheel - steel to steel - its not there all the time, but when it is - its loud - like a wheel bearing - usually from the rear wheels - also - my Mariner - was missing rubber **** too - on the tail gate - and on some of the doors - 5 in fact - a small thing - but they have since been installed -
PHIL
Old Dec 18, 2006 | 04:21 AM
WaltPA's Avatar
I had something like the sound you reported.
I found a mention of it here, and the suggestion of putting the parking brake 'on' quickly while the hybrid was in a slow forward motion. I did that, and the sound stopped immediately, and hasn't come back
Old Dec 18, 2006 | 04:27 AM
PML's Avatar
PML
Thanks Walt - I will try that the next time - thanks for your reply - as the foot brake did not stop it - but I will try the handbrake the next time - Thank you
Old Dec 18, 2006 | 04:35 AM
twuelfing's Avatar
possibly its a dragging parking break? I have had a similar sound when a dust shield was bent into the break disk on my wifes corolla.
Old Dec 18, 2006 | 06:08 AM
Thegreatescape's Avatar
Ford has published a servive procedure for this. It's special service mesaage 19121. It appears to be a very minor issue. Here's the text of the message for you - SOME 2005-2006 ESCAPE HYBRIDS BUILT FROM 8/2/2004 TO 11/21/2005 AND 2006 MARINERHYBRIDS BUILT FROM 10/1/2005 TO 11/21/2005 MAY EXHIBIT A SQUEAKING, SQUEALING ORGRINDING NOISE FROM THE REAR BRAKES WHILE DRIVING. THIS CONDITION MAY BE DUE TO A MISADJUSTED PARKING BRAKE. IF THIS CONDITION IS PRESENT, CHECK THE AMOUNT OF THREAD PROTRUSION OF THE PARKING BRAKE CABLE ADJUSTER AT THE PARK BRAKE LEVER. SET THE ADJUSTMENT SO THAT THERE IS 10MM, PLUS OR MINUS 1MM FOR VEHICLES BUILT BEFORE 5/3/2005 AND 15MM PLUS OR MINUS 1MM FOR VEHICLES BUILT ON 5/3/2005 OR AFTER. IF THIS CONDITION PERSISTS AFTER ADJUSTMENT IT MAY BE NECESSARY TO CLEAN THE PARK BRAKE DRUM AND SHOES OF EXCESSIVE LINING BUILD-UP.
Old Dec 18, 2006 | 08:09 AM
Duc's Avatar
Duc
Stock Sucks
Very interesting, I can/will try the parking brake to see what happens. I notice it most when we are coasting (in gear), not sure how or why the parking brake would affect it if pushing the brake doesn't but who knows.
Thanks for the info/ideas.
Clif
Old Dec 18, 2006 | 08:47 AM
nash's Avatar
Clif
The parking brake is a small drum brake, not connected to the rear hydraulic brakes. Using the brake pedal only acutates the hydraulics, engaging the front and rear calipers if regen can't supply enough stopping power.
My FEH parking brake gets "squeaky" after a while, making a noise anytime I get in or out when the parking brake is set. It sounds like a squeaky suspension, but is really the parking brake. I find it helps to do an occasional low speed stop with the parking brake. By low speed I mean stopping from about 10mph using the parking brake.
Old Dec 18, 2006 | 08:52 AM
Duc's Avatar
Duc
Stock Sucks
Ah now that makes since, wondered how the brake worked with rear disc's and now I know.
Thanks I will try it
Clif
minghi
Feb 27, 2012 12:54 PM
Momboy007
Mar 28, 2006 07:03 AM
newhybrid
Dec 3, 2005 08:16 PM
CGameProgrammer
Aug 10, 2005 07:05 AM
wwjdrv
Website Questions & Input
Aug 6, 2005 07:24 AM
