nitrogen vs air in tires
Old Oct 24, 2005 | 10:22 AM
gonavy's Avatar
Default Re: nitrogen vs air in tires
Please use the search feature for previous threads on N2 filled tires.
Bottom line: N2 is "dry" out of the bottle- no water vapor. The air you pump into your tires at the gas station has a lot of moisture in it. The presence of water vapor outstrips most other factors as it cools and heats.
O2, N2, He, air, etc all more or less obey the ideal gas law because they are not near their condensing point, so they all behave about the same. Water vapor is definitely not an ideal gas at normal temperatures and pressures; its behavior masks many other effects.
Yes, the N2 molecule is larger than the O2 molecule. By a few Angstroms...a tenth of a billionth of a meter. I really doubt the pore size of modern tires cuts off at that scale.
Old Oct 24, 2005 | 12:20 PM
stevewa's Avatar
Early Adopter
Of course, in order to make this work, you need to completely evacuate the air from the tire before inflating with N2. That's not what's happening here. There's still air in the tire, and there will be more air in the tire as you check and reinflate them during their lifetime.
Old Oct 24, 2005 | 12:46 PM
nitramjr's Avatar
Originally Posted by nitramjr
To get pure N2 in a tire you would have to evacuate the tire completely, not just let the air out.
I doubt highly that tires are (or could be) evacuated so that you had 100% pure nitrogen in the tire.
stevewa Of course, in order to make this work, you need to completely evacuate the air from the tire before inflating with N2. That's not what's happening here.
I guess great minds think alike....
Old Oct 24, 2005 | 12:54 PM
Delta Flyer's Avatar
Banned
I guess this is another one of those "snake oil" products?
Old Oct 24, 2005 | 01:00 PM
livvie's Avatar
unless you are racing, it's pure snake oil.
H2O Doctor
30
Aug 15, 2006 05:59 AM
dsusskind
Aug 13, 2006 07:40 AM
ppgroup
Jun 14, 2006 08:23 PM
team_venture
22
Nov 13, 2005 08:50 AM
