New SGII Problems
Old Nov 15, 2008 | 11:09 AM
  #41
GaryG's Avatar
Default Re: New SGII Problems
Originally Posted by gpsman1
Gary, what does the 2009 show for LTFT with E10?
It will move around slightly, but what's the average?
It should be positive if you have ethanol, and near zero if you have gas only.
This has been a good way for me to tell the difference if the pump is not labeled, or if I am in a state that does not require labels.
Since the mandate, all gas pumps are labeled "This Gas Contains Up To 10% Ethanol". Port Everglades where all our gas comes from converted their storage tanks and equipment to handle ethanol around April this year. My '09 FEHL handles ethanol well, but my '02 Explorer, '05 FEH, and '94 Evinrude 150 all have issues with E-10. The explorer has problems idling when cold, the '05 has a lost of power and MPG, and the 150 is missing very bad at low RPM's. I'm sure the ethanol cleaned the inside of my Whaler's gas tank and mixed with any moisture. I plan to change the filter/water separator before I take the boat out again this month. Remember it's lobster season here and our weather is still in the low 80's (rubbing it in a little).
GaryG
Old Nov 15, 2008 | 01:06 PM
  #42
colchiro's Avatar
Gary, I'd check the compression and ignition-related items on the explorer and 05. I suspect much of your problems is age, salt or humidity-related, not ethanol. I ran E60 on my Rav4 for 6 months, (before adding a conversion) and only had a loss of 3 mpg (22 vs 25 mpg). I haven't heard Billyk complain about loss of power in his '05 with 30%.
Old Nov 15, 2008 | 02:56 PM
  #43
GaryG's Avatar
You don't have the moisture problems and your 02 sensors in your Rav4 may be a better quality than my Fords. I've talked to mechanics that told me they had to take out many 02 sensors and clean or change them since we switched to ethanol. Once my Explorer warms up it's ok. Once all the water has mixed with the ethanol and burned, it may solve my problem. The loss of power and MPG has been documented in my mileage in the '05 FEH over the years. I've got gas with ethanol a number of times before it was mandated here and posted the effects many times. The Long Term Fuel Maps stored in Keep Alive Memory (KAM) were a problem, but now that I've ran nothing but E10 for 6 months, I see it's permanant. If you've never had straight gas adjusted to the FEH, you most likely don't know the benefits in mileage and power.
GaryG
Old Nov 15, 2008 | 03:08 PM
  #44
colchiro's Avatar
The guys in the e85 forum brag about how clean their o2 sensors are. Go figure.
Old Nov 15, 2008 | 04:35 PM
  #45
It is interesting to know where I live in Southwestern Pa. there is no E10. It is straight 87 octane. After I run a mixture of E20-35-30---it takes less than 20 miles for my Long term fuel trims to "normalize" when I return to straight gas. On straight gas, my LFT is always under zero unless I am going up a hill and then it is no more than four point zero.
I have gotten as low as -14.9 LFT on straight gas
On straight gas going up a 9% 5/8 mile hill
On E30, I can "score"a LFT of 14.0
and drop down to zero:
update: The vehicle's LFT dropped to minus 1.6 today. Name:  minus16lfton422.jpg
It was snowing and is in the low thirties on this drive. The vehicle's LFT value slowly but progressively drops upon deceleration/fake shifting as the vehicle utilizes this fuel. It initially has a LFT value of 2.5 to 3.0 after the initial fillup and slowly leans its self.
I'm down to 12 miles to empty on my current tank and need to fill up in the next day. Maybe I can reset my digital camera to show how rapid the LFT reset.
Old Nov 16, 2008 | 03:22 AM
  #46
Once again,
Old Nov 16, 2008 | 03:55 PM
  #47
GaryG's Avatar
Billy, I think the SGII LFT your seeing is the current PID and not the Long Term Fuel Maps stored in KAM. The LONGFT1 PID is for diagnosing fuel trim concerns. A negative PID value indicates the fuel is being reduced to compensate for a rich A/F mixture, and a positive PID indicates the fuel is being increased to compensate for a lean condition. This is not the same as stoichiometric (14.7:1) being rich above and lean below. There is a separate LONGFT that is used for each RPM/load point of engine operation. When looking at the LONGFT1 PID, the value may change a great deal at different RPM and load points. This is because of the learned corrections stored in KAM. In other words, once the RPM/load point is learned, the A/F mixture should not need to be compensated from the learned Long Term Fuel Maps.
If your seeing a positive PID number with ethanol in general, this means more fuel is added (lower MPG) to compensate for a lean condition. On the other hand if your seeing negative PID numbers with straight gas, your reducing fuel to solve the rich conditions. Ideally, you want to use the stored Long Term Fuel Trim Maps in KAM so your not constantly adjusting the learned data. This is one purpose of KAM. If you think every RPM/load point is relearned and stored in 20 miles, I beg to differ. My mileage drops for almost three tanks even after a reset of KAM to the default setting. When you change the energy of your fuel by adding ethanol, the fuel maps all change for each and every RPM/load point.
GaryG
Old Nov 16, 2008 | 08:23 PM
  #48
LTFT displayed on the SG is, of course, the fuel trim being applied at that moment, in real time. So yes, it will move slightly ( or occasionally, greatly ) with changing driving conditions. However, it will "hang out" at a average point.
If the "average" is positive, it is a good indication you have ethanol in the tank. If the "average" is negative, it is a good indication you are at some significant elevation above sea level.
If you switch back and forth from ethanol, especially high amounts of ethanol, back to straight gas, yes, it takes time to "re-learn".
If you switch fuel, and get right on the highway, the LTFT will adjust to highway conditions ( aka 2400 RPM and gentle load ) pretty fast ( within minutes ). However, like Gary says, until you have run the car at ALL RPM's and various load condtions, the car has not completely adjusted yet.
Gary, do you want me to give you the SG code for LTFT so you can try it in the 2009 with Florida fuel? You don't always get exactly 10% ethanol.
-John
Old Nov 17, 2008 | 07:55 AM
  #49
GaryG's Avatar
-John
If the Scangauge.com site has the correct LFT, I don't need you to re-post it. The signs on the pumps here do say up to 10% ethanol and I know mixing that stuff can vary with bartenders.
GaryG
Old Nov 17, 2008 | 07:53 PM
  #50
GaryG
Exactly. That's what I was getting at. Ethanol plants had a margin. They could sell and transport E98, E93, or anything in between. So at gas stations, you could get E12.5, E7.5, or anything in between, all sold as "E10".
Just like a box of chocolates, "you never know what you're gonna get".
I just heard some insider information.
Effective Jan 1, 2009 all ethanol plants will only produce and ship E98.
What I don't know yet is, who made this decision.
If it was voluntary by the industry, or if there was some gov. mandate.
Details to follow.
-John
Guss
25
Sep 6, 2019 06:13 PM
2k3 Mach
Jun 21, 2011 03:07 PM
stevedebi
Jul 9, 2009 11:26 AM
GaryG
May 10, 2009 08:51 PM
