MP3 and Sirius in 06' w/Nav
Old Apr 21, 2007 | 11:43 PM
  #51
MarinerGreen's Avatar
Default Re: MP3 and Sirius in 06' w/Nav
Regarding the false advertising from mercury It was just so difficult here in California there is a two year time limit for filing small claims. I just traded my MMH for a 08 FEH, took a down grade without the NAV and I am much happier.
Old May 26, 2007 | 03:18 AM
  #52
virtualfreak's Avatar
Does anyone have any information regarding whether or not the 2008 FEH factory nav radio would be compatible to install in a 2007 or earlier model? It's not made by visteon (I think pioneer) but as long as the signal pinouts and physical fit are compatible it would be possible.
Old May 26, 2007 | 10:14 AM
  #53
TeeSter's Avatar
If someone tries this, see if you can't get a return on the system if it doesn't work. As I've said before car companies could car less about backward compatibility. I'm sure the radio will work fine, but even if the physical interface is copatible, there would be no guarantee the communications messages passed for the hybrid screens would be compatible. She might lock up. She might not... It would suck only to find out after a grand or two expenditure.
Old May 26, 2007 | 06:57 PM
  #54
Tim K's Avatar
Physical dimensions are different. The 2008 unit is about 3/4" taller than the previous NAV unit.
Old Jun 7, 2012 | 08:40 AM
  #55
hc45's Avatar
Hello, i have read many of threats about what to install in my FEH 2006 with NAV radio.. i have the 6 cd box under the passenger seat.. but i really want to play my MP3 USB..
Could you on easy understanding let me know what to buy and how to install and how its works and of course your satisfaction .
Thank you.
H
Old Jun 8, 2012 | 12:41 PM
  #56
frankthomas's Avatar
Thank you.
H
I had the XM commander installed in my '06, basically its an FM modulator that shares the AM/FM antennae plug with the radio. You tune the radio to 87.9, turn on XM, and voila, you have pretty good satellite radio. That was a professional install.
More recently I went to a local car stereo shop to see if there was a way I could add in audio input jack to play from an MP3 player. They have such a thing, the install cost was around $50, the provide in dash aux input plug and a toggle switch. The aux input is also an FM modulator. The toggle switch allows one to toggle inputs between XM and the AUX Mp3 player.
I asked if there was a way to wire in something considering I also had the CD changer without a having to use another modulator and the answer was no. The $50 solution made alot more sense
Old Jun 10, 2012 | 08:41 AM
  #57
hc45's Avatar
Question Re: MP3 and Sirius in 06' w/Nav
Hello, thank you for your help..
Could you please let me know what exactly is the Thing... that cost you $50.. i will like to make an aux input in my NAV radio and play MP3...
If is possible, the web address of the local stereo shop, or they email.. to find out.
Thank you.
H.
Old Jun 10, 2012 | 12:01 PM
  #58
Thank you.
H.
The gadget is something like this:
http://www.hifisoundconnection.com/i...dular-W-Switch
or
http://www.crutchfield.com/p_142FMMO...2.html?tp=1701
Just call your local car stereo shop and tell them you need something like the above
tinu2005p
Honda Motor Company/Acura
Apr 21, 2010 05:17 PM
Jerry&Natalie
Jan 10, 2010 09:52 AM
ToyotaGoblin
Jun 15, 2007 08:21 AM
dogzen
Mar 13, 2007 08:08 PM
bmgoodman
Jun 14, 2006 02:31 PM
