Master MP3/Wiring Thread
Old Jul 8, 2008 | 10:10 PM
  #91
Eric91780's Avatar
Default Re: Master MP3/Wiring Thread
Do I have to use one of these interfaces or a fm modulator to listen to my ipod through my stereo system?
I have a 2007 Escape with a cd changer.
Is there a way I could just splice into the audio in lines from the cd changer and put a simple multi wire switch in from radio shack to switch from cd changer to ipod.
I dont mind having to control my ipod from the actual ipod.
Is this system realy that complicated that I must use a $120 interface?
Sorry if I missed something in all pages on this thread.
Old Jul 25, 2008 | 02:10 PM
  #92
grnhybrid's Avatar
Lt. Green 06 FEH
Well, not sure if its worth the trouble of trying to kludge into the harness.
For $150 from LogJam I was able to do a nice clean install with the harnesses they supply. Mine had the 16pin connector. Use the SAT button and the radio thinks your ipod is a satellite receiver. Displays text, scans, search, etc. Sounds is excellent too, true line-level sound, sooo much better than an FM modulator.
I think it was well worth it.
http://www.logjamelectronics.com/piefrd03pods.html
Old Jul 31, 2008 | 03:45 AM
  #93
greenhybrider's Avatar
Has anyone used the PIE FRDW/PC-POD2 iPOD® interface to hook up to a iphone 3G?
I am curious to try out the iPhone on this!
Old Jul 31, 2008 | 04:47 AM
  #94
So even after two years, no manufacturer has come out with a harness that will allow the simultaneous use of IPOD (with headunit control) + CD changer (without disconnecting it)????
Old Jul 31, 2008 | 07:19 AM
  #95
grnhybrid's Avatar
Lt. Green 06 FEH
mine allows the in-dash cd changer to work.
Old Jul 31, 2008 | 11:55 AM
  #96
It doesn't seem like the Escape models with navigational radio are able to work with the harnesses to have both ipod and CD changer, am I right?
It seems only Escape models with Sat capability are able to take advantage of the interface.
Old Aug 30, 2008 | 05:59 AM
  #97
deezwho's Avatar
has anyone figured out all the various pins on the back of the radio?
Old Sep 8, 2008 | 07:49 PM
  #98
ranger01's Avatar
The non nav system, has an 'aux' button but no input. So, is there a way to direct connect an ipod to this system?
Old Oct 21, 2009 | 06:15 PM
  #99
fehy06's Avatar
Would any of the solutions described for an external mp3 player also work for a Sirius radio without the Visteon adapter? Has anyone tried it? Can you feed the Sirius display into the Visteon radio display?
-Dave
Old Nov 6, 2009 | 05:12 PM
  #100
cooperk851's Avatar
is there anyway to just AUX cable an ipod into the system? Because When you use an AUX cable it is generally much clearer than FM transmitter. The second thing i would like to know is if anyone has put systems in their FEH's. I don't want to go with a huge sub in the back, i just want to wire tweaters in.
