Instant Econ Calibration
Old Aug 20, 2006 | 11:13 AM
jginaz's Avatar
Default Instant Econ Calibration?
Has anyone tried to calibrate the instant econ bar graph?
Jay
Old Aug 20, 2006 | 03:51 PM
nitramjr's Avatar
Default Re: Instant Econ Calibration
Are you trying to relate the number of bars to a fuel efficiency number? It would be great if there is a relationship. I bet if someone with a scangauge were to do some tests (calling GaryG) then the relationship (if any) could be determined rather easily.
I have often wondered why they would put this gauge on the cars and not put the instantaneous mpg gauge on there instead. They probably knew we would never stop looking at it.
Old Aug 20, 2006 | 04:30 PM
jginaz's Avatar
MPG per bar, or MPG per distance from L if non-linear.
JG
Old Aug 20, 2006 | 06:10 PM
randykato's Avatar
I don't think there's any correlation there. Theoretically, it seems impossible to quantify since it's "instantaneous." Any meaningful MPG number needs to occur over time and distance. Otherwise, I'm getting "infinite" MPG much of the time.
I think it's more of a relative thing... worse - bad - ok - good - better. If you want to see numbers, just use the Average Econ and reset it at will.
Old Aug 20, 2006 | 06:20 PM
TeeSter's Avatar
Default Re: Instant Econ Calibration?
I don't understand... there isn't anything to calibrate.... its on the same scale as the rest of the graph. If its three lines up you are running at an instantaneous rate that would get you 30MPG.... etc. If you are on a flat level surface and can hold the instant bar at one point longer than a minute you'll see what I mean. Basically when the average graph to the right updates the green will be at the same height as the instantaneous bar was... so its on the same scale as far as I can tell.
Old Aug 20, 2006 | 06:59 PM
everythingsgonegreen's Avatar
I believe they're referring to the instant bar graph in the message center, not the nav unit.
Old Aug 20, 2006 | 07:08 PM
jginaz's Avatar
I don't have a nav unit so I was interested in a calibration of the instant econ on the speedo.
JG
Old Aug 21, 2006 | 04:46 AM
nitramjr's Avatar
You could say the same thing about almost any gauge or meter. Your speedometer only reads your instantaneous speed but we all us that all the time. I had a rented Buick once that had an instantaneous mpg gauge and it came in quite handy.
I'd prefer that to the practically useless bar graph that I never use.
Old Aug 21, 2006 | 04:51 AM
WaltPA's Avatar
My parent's old Cadillac had one of those. It either read 5 or 49, depending if you were pressing the gas pedal or not. Neither number was very helpful.
PiroChu
Jun 14, 2010 11:36 AM
donald_s
10
Aug 20, 2006 07:51 PM
SAM Hybrid
Mar 12, 2006 08:38 PM
Dale B
Apr 11, 2005 07:34 PM
tbaleno
Mar 24, 2005 12:06 PM
