I ran the 12 volt battery down on vacation.
Old Oct 26, 2006 | 07:31 PM
TeeSter's Avatar
Default Re: I ran the 12 volt battery down on vacation.
Originally Posted by Seattlemander
This seems as good a place to ask as any thread I've read.
I don't have the NAV or a scangauge. And I read lots of complaints that scangauge doesn't include SoC, anyway. Am I being naive to think that one could wire in a voltmeter to give constant feedback regarding the SoC? Then, I could notice when the ICE kicks in and learn when I'm about to go too low. Or when I've tried to put too much back in.
Sorry, if it's been discussed to death. I searched and searched....
Scott
Not a dumb question. There are a couple of things to know about that path though. Wiring a voltmeter into the 12V system would be pretty easy, but we want to see the HV battery and its 330V... I'd be a bit nervous about tapping into that system as its fairly dangerous to mess with it.
Second has to do with how rechargable batteries discharge. Alkalines and the old Rayovacs you used to use discharge so that the voltage falls pretty much linearly as they go down. But NiMH, and NiCd (not sure about Li-ion but they have their own issues) acutally hold their rated voltage as they discharge. Our battery probably starts with a voltage above 330V and falls a bit fairly quickly..... but then it would hold at right around 330V right up until it was nearly empty... then drop like a rock! So you'd get a guage that would tell you 100%-90% fairly well...but then it would stay near 90% until it died and that last 90% would look like it lasted a minute! Also whenver the generator kicks on and charges the battery you'd loose your ability to see what the charge was becasue you'd be reading the charging voltage (above 330V)
In order to see charge on this kind of battery you actually have to count the coulombs as they go into and out of the battery with an ammeter and you have to add them up. This is one of the reasons older laptop battery guages were pretty poor... the algorithms for how they discharge and how their capacity changes each time they charge weren't very well known at the time.
I can't guarantee all of that is perfectly accurate for our NiMH pack. I'm an EE and I've worked on battery powered systems for several years in handheld devices. I know about the little NiMH packs, NiCd, and LiIon, not the large ones. But the chemistry is bound to be similiar and likely so is the behavior.
Old Oct 27, 2006 | 06:45 AM
Seattlemander's Avatar
Originally Posted by TeeSter
..-snip-... I'd be a bit nervous about tapping into that system as its fairly dangerous to mess with it.
...-snip-... but then it would hold at right around 330V right up until it was nearly empty... then drop like a rock! So you'd get a guage that would tell you 100%-90% fairly well...but then it would stay near 90% until it died and that last 90% would look like it lasted a minute!....-snip-....
Thanks for the reply, Tim. I figured it couldn't be that easy, or everybody would be doing it. I'm not smart like you EE's, but I've got friends who are used to diving into high voltage stuff (we build industrial equipment). But, if it wouldn't do me any good, that's the bummer.
Thanks, again!
Scott
Old Oct 28, 2006 | 07:36 PM
The voltage swings are huge. I've drivin with a HV volt meter, and while Regen brake charging, the voltage can be as high as 424 volts.
Accelerating from a stoplight, the voltage can be as low as 270 volts.
424v ( charge ) to 270v ( under load ) within seconds of each other.
May be fun to watch, but with swings all over the place, not really useful info.
The resting voltage when you park ( key off ) may be pretty accurate. ???
Good thought though!
-John
Old Oct 29, 2006 | 04:31 PM
Bosh's Avatar
I would love to try running a meter while driving. Can you give some more info on how you did it so I don't kill myself.
Old Nov 1, 2006 | 01:05 PM
It was with Ford's Equipment, and a Ford Tech driving... I was in the passenger seat... you could tap the battery pack in the rear with something as simple as alligator clips, but do be careful... and I don't really see a lot of benefit from doing so... I already told you ( below ) what most people are curious about.
Squint
Sep 23, 2007 01:44 PM
chuckokie36
May 16, 2005 06:49 PM
lars-ss
May 9, 2005 09:41 AM
infael
Jun 24, 2004 10:35 AM
