Hybrid battery warmer for 2009+
Old Jan 31, 2013 | 08:57 AM
stevedebi's Avatar
Default Re: Hybrid battery warmer for 2009+
Originally Posted by robingf
Good to hear that it's feasible. Might you have the actual Ford Part Number for the required connector at the Battery, by chance ? That's what I'm really looking for....I have the one for the Charger/Transformer, can build a functional wiring harness...just need the connector, I think.
Thanks,
Gary
The question is if your 2008 was setup for the heating option. I have read on this site that only early model 2008 had the connectors installed. Mine was built in late 2007, so it probably has it, although I'll never need it here in LA. What is your build date?
Old Jan 31, 2013 | 09:15 AM
us035976's Avatar
There is a post https://www.greenhybrid.com/discuss/...03/index7.html (post #62) that shows where to check and see if you have the wiring and therefore the battery heater in you vehicle. Just fold down the back seat on the drivers side and lift up the rear cargo area mat.
Then the parts you need should be:
4M6Z*6B018*AA WIRE ASSY - This is the 120V cord to plug it in
F5RZ*6A051*B HEATER ASSY - Engine block heater
5M6Z*10B689*AA WIRE ASSY - CHARGER HIGH VOLTAGE - The 120V -> 24VDC power supply for the HV battery heater
I hope this helps.
Aaron2
Dec 8, 2012 08:45 PM
hugoland
Sep 1, 2009 09:06 AM
noflash
Dec 15, 2008 08:10 AM
Billyk
Jan 23, 2008 04:02 PM
kristian
Sep 15, 2007 04:26 AM
