HV Battery Jump
Old Jan 19, 2020 | 07:07 PM
  #81
Default Re: HV Battery Jump
2X APC-35-350 peak at 200V. If you're going to use them, you need to add 2 more.
Old Jan 20, 2020 | 03:34 PM
  #82
mca1990's Avatar
Ah. The HCH2 talk mixed in with the FEH talk threw me off. Just to be clear, can I use just 1 HLG-120H-C350A with a 120v source to charge the Ford Escape Hybrid? Some of the other power supplies listed along this thread have been on back order for a while, but he HLG-120H-C350A is in stock right now on Mouser. It seems easier to return the APC-35-350 and just use that instead if I can.
Old Jan 20, 2020 | 05:03 PM
  #83
HLG-120H-C350A should work fine with 90-305VAC input and 127-431VDC output at 0.35A. Current can be decreased via the dimmer, but there's no reason to do that.
Old Jan 27, 2020 | 11:19 PM
  #84
Tribu Tibas's Avatar
It works buddy. I charged mine using 1 HLG-120H-C350A because all the other parts were on backorder.
Old Jan 27, 2020 | 11:38 PM
  #85
mca1990's Avatar
Alright. Thanks for the info guys. I am going to attempt this project this weekend if the weather is nice. I am going to try to open the battery without fully removing it from the car. We'll see how this goes. I plan to document the process along the way.
Old Jan 28, 2020 | 12:18 AM
  #86
Are you actually in a situation where the vehicle will not start due to HV battery low voltage?
Old Jan 29, 2020 | 11:18 PM
  #87
mca1990's Avatar
Yes Sir. My 2009 FEH has been immobile since July 4th last year. The car was a fleet vehicle at < 70,000 miles that I bought in April 2019. Hybrid battery as well as 12v battery were replaced sometime in Fall 2018. They replaced it with a Dorman battery. I towed it to Ford and they wanted me to buy an brand name battery for $9,000 before they would try to diagnose it. Instead I took it back home and I used Forscan to get a few codes of the battery. The battery voltage would read as low as 190v at when I turned the key, and slowly charge up to ~260v as I left the car powered on.
Here are the codes I read:
PCM DTC P1A10
BCM DTC P0A27-60
BCM DTC P0AE1-60
BCM DTC P0A1F-60
I appreciate the wealth of information you've shared on this forum. I have called everyone in town that I think could've helped me, I even called the doorman hotline labeled on the battery. I have checked everything I could in the car that doesn't involve opening the battery up. I think this is the next step before I consider scrapping the car.
Old Jan 29, 2020 | 11:43 PM
  #88
260V is WAY too low to start the vehicle. Step 1 is definitely to charge it and see what's next.
Old Apr 13, 2020 | 10:53 PM
  #89
avinator's Avatar
Thank god i am reading good results from this post! I was about to buy me a Prolong Battery charger (very expensive) to charge my Hybrid battery. Thanks for the valuable info!
Old Apr 13, 2020 | 11:53 PM
  #90
avinator's Avatar
Hello sir,
I am planning to recharge my HV battery pack with the same HLG-120H-C350A. I also purchase 2x D1NK60-5070 diode. Would like to confirm if 2 diodes is needed to charge or one is enough?
Thanks in advance!
