HV Battery Jump
Old Sep 16, 2020 | 06:13 AM
  #171
LT1Burb's Avatar
Default Re: HV Battery Jump
Originally Posted by econoline
My only experience is with Forscan on Android and it ran without any issues. The menu for rebalance is under "Services".
Are you able to run other Forscan tests and read data on the iPad, or it crashes just running Forscan?
No, I can do everything else except the rebalance feature.
Old Sep 16, 2020 | 12:39 PM
  #172
econoline's Avatar
You might want to check with the developers on the Forscan forum, I have no idea. https://forscan.org/forum/
Old Oct 4, 2020 | 09:28 AM
  #173
Updated post #1 to:
  • Add the link to post #115 referencing the tool that enables removing the side torx bolts in-place.
  • Add link to post #116 for additional information.
  • Add reference to channel locks for the lifting strap bolts.
  • Add reference to a 100% charge process.
  • Add recommendation for use of Forscan balance function.
Old Mar 8, 2021 | 04:05 PM
  #174
hinesite's Avatar
Same problem with 2009 FEH. Does anyone know anyone in Baltimore/Washington DC area that can do this?
Old May 3, 2021 | 07:46 PM
  #175
ShadyEscape's Avatar
I have 180V on the pack and a P0A1F_11 VT sensor 2, module voltage sense line fault. Do you think a charge will bring it back?
Old May 3, 2021 | 07:58 PM
  #176
No one can answer that question. The only certainty is it will never start with the HV battery that low.
Old May 4, 2021 | 05:52 AM
  #177
Where should I look for info on P0A1F_11_CM. So far have found nothing on internal battery troubleshooting. I'm going to install the charge wire and probe the cells I can access but don't see info for any more than that.
Old May 4, 2021 | 05:55 AM
  #178
Except in rare cases, Ford does not support internal service of the battery. The only thing I can think of is fan replacement, and the TSB that corrected a cabling issue.
You can access all Ford manuals for something like $20 for 48 or 72 hours (can't remember):
https://www.motorcraftservice.com/Ho....com%3A1402%2F
Old May 4, 2021 | 03:50 PM
  #179
Question for SKeith: I have not tried the Forscan balancing function but I want to. It doesn't require anything "external" in the way of chargers attached, am I correct about that? Just plug the laptop and run it (basically) ?
Old May 4, 2021 | 05:04 PM
  #180
Correct. It can take some time. Make sure your laptop has sufficient charge or is plugged in.
