Ford recalling 2005-2008 FEH for MECS Pump
Old Nov 19, 2014 | 01:47 PM
econoline's Avatar
Default Re: Ford recalling 2005-2008 FEH for MECS Pump
Still haven't received the recall letter, although I can see that my VIN is part of the recall on https://vinrcl.safercar.gov/vin/.
Wondering if I need the recall letter or if I should just take the FEH to the dealer. I've already replaced the MECS pump myself so just need the dealer inspection to get the reimbursement process started. Reimbursement window ends in April '15.
Old Nov 23, 2014 | 07:40 AM
OT7's Avatar
OT7
Received my check for cost of MECS pump + 1gal. coolant under Ford general
reimbursement plan. My Ford dealer did not verity the replacement MECS pump.
Old Nov 23, 2014 | 09:54 AM
econoline's Avatar
Richard,
Can you give me a few details about how that worked?
Did you get a recall notice but not do the inspection at the dealer?
How did you apply under the Ford general reimbursement plan? Is there a form somewhere? Did you have to submit the receipt for the MECS pump?
Thanks for any info?
Old Nov 23, 2014 | 04:12 PM
OT7's Avatar
OT7
Don
Got a recall notice and went to dealer to submitted MECS pump + coolant receipt.
There is no form have to go thru dealer. 2 weeks to get check. My Ford dealer did not verity the replacement MECS pump service writer unsure of policy.
Old Nov 24, 2014 | 03:16 PM
econoline's Avatar
I got tired of waiting for the recall notice and called the dealer today. They confirmed the recall on my VIN, scheduled a service appointment for the inspection, and told me how to start the reimbursement process directly through Ford.
The only reason for the inspection is to close out the recall on my vehicle. Otherwise the recall stays pending if I sold the FEH or had it in for service.
Old Dec 4, 2014 | 11:08 AM
tommyball's Avatar
Just some info that may help those who have had the recall work performed previously:
I called the customer service number on the recall notice and was told that a dealer service center (not any QuickLane centers) needs to inspect and verify the work. If the work done is correct, the Service Manager needs to file the necessary refund paperwork. It should take approximately two weeks to receive the check.
Old Dec 4, 2014 | 03:47 PM
  #27
econoline's Avatar
I had my appointment at the dealer yesterday. The inspection takes just a few minutes obviously, and I got a service invoice saying "HAS UPDATRD PUMP". I was told to submit the service invoice and my original receipt for the pump ($189) to Ford Motor Company, P.O. Box 6251, Dearborn, MI 48121-6251 and may take upto 60 days for the reimbursement. I'm sending the paperwork via Priority Mail with tracking.
Old Dec 15, 2014 | 02:57 AM
  #28
I took my FEH in for basic maintenance work and the MECS recall. I did not have any warning lights or issue with my MECS pump even at 121,000 miles. The service manager read the recall to me and essentially stated "it's not free unless the warning light is on". I will be sending my invoice to FORD for review.
Old Dec 15, 2014 | 08:07 AM
  #29
OT7's Avatar
OT7
NHTSA Recall No. 14V-526
If the original equipment pump is found, it will be replaced with an improved brushless pump.
Old Dec 15, 2014 | 09:16 AM
  #30
econoline's Avatar
As OT7 said, this is an "inspect and replace" recall. Nothing in the recall notice about a warning light having to be on.
