FEH/4WD/Scanguage-II
Old Oct 2, 2009 | 11:12 AM
  #101
wwest's Avatar
Default Re: FEH/4WD/Scanguage-II
Originally Posted by Bill Winney
My purpose was to get desertdog to post his stuff so I can learn along with others. Didn’t necessarily intend to run him out. I am finding that there is a propensity for some to read the scangauge and presume too much knowledge. (***1)
My intent in pointing out that the shop manual doesn’t differentiate between these 4wd systems was to get folks to understand that it is precisely the same system. Thought it would be apparent.(***2)
My take on how this thing works is that it monitors the wheels thru the anti-lock brake sensors. When the system detects what Ford wanted it to, wheel spin, heavy load, etc, then it kicks in the rear axle. 10%, 40%, 80%… does it really make a difference?(***3)
I don’t have a scanguge. May eventually buy one, I have a system for a computer that can read out my Mustang & Suburban, but found them of lesser value in troubleshooting. The perception that the computer can tell all, as opposed to just paying attention to the car, leads some down spurious paths (ie… could not duplicate…).
***1. Yes, it still seems to be a puzzle as what exactly what the scanguage readout meaning is as relates to the rear drive coupling. Even the O'scope display is subject to differing interpretations. An electric solenoid might have FULL voltage applied initially and the reduced to a low holding voltage/current to simply hold the plunger in place. So even with the 25% duty cycle the solenoid plunger/actuator might be fully "deployed".
Absent a dynamometer I don't see how any of us could correlate voltage duty cycle % with the level of rear drive coupling.
***2. Mechanically the same does not necessarily correlate to firmware version be equal. It might be exacly the same revision or may be quite radically different. As a for instance what if, instead of reducing the regen capability as the OAT declines to freezing why not first begin engaging the rear drive coupling to help alleviate the potential for loss of control due to regen.
***3. Well, yes. We now know when the rear drive is pre-emptively engaged. That is, only when accelerating from a dead stop or low speed acceleration. Otherwise only the front wheels have "drive" at least primarily (95%..??).
The various materials I have been able to find indicate that when front wheelspin is detected three things will occur pretty much simultaneously. TC braking of the front wheels, BOTH front wheels, engine dethrottling, and engine torque coupling to the rear driveline.
The question becomes.."how long will the above "condition" persist..??"
Old Oct 2, 2009 | 11:14 AM
  #102
wptski's Avatar
Imported from Detroit
Originally Posted by wwest
I'll stand by those statements. On a highly tractive surface on a RWD vehicle there would be NO need for additional roadbed traction EVEN if the rear driven wheels were to begin to slip/spin, you would still have the FULL traction conefficient for use to maintain directional control.
That doesn't apply to FWD and F/awd vehicles and I would especially add the hybrid versions of those to the list since they have such a great ability to generate an extraordinary high level of low speed torque.
So loss of traction on the front wheels is a much more serious matter than on the rear.
After you proved, confirmed, it to be so, the follow on question arose as to why the rear drive would be automatically coupled in when accelerating from a dead stop. Obviously that could ahve been done ONLY if the OAT were near or below freezing.
What's the saying..
An ounce of prevention is worth a pound of cure..??
The couping is being use on the somewhat rare chance that unknown to the driver the surface is not tractive enough to support acceleration of the vehicle absent bringing up the traction coefficient.
The alternative is to go ahead and let wheelspin develop on those rare occassions and then HAMMER the brakes using TC and dethrottle the engine simultaneously.
Which would you prefer..??
A little tire "scrubbing", ~5% loss of tread life, each time you start out from a dead stop or a rare but totally appropriate reactive TC activation?
Your saying the they send rear wheel torque, just incase or unknown to the driver, there is poor traction?
Your are forgetting one thing. As many times as I have tried, I can't leave a dead stop without getting rear wheel torque no matter how lightly I touch the throttle. Light, moderate or hard, I get the same results!
Old Oct 2, 2009 | 11:27 AM
  #103
wptski's Avatar
[quote=wwest;211827]
Originally Posted by stevedebi
*** I would have used the term "predict" rather than "sense" but then maybe the FE/FEH does sense OAT as a "component" as to how much rear drive coupling to use in accordance with temperature....or rain(wipers on...??)...??
Someone with a scan guage want to put the OAT sensor in an ice bath for a few minutes and then check to see if the level of coupling to the rear with low speed acceleration to the rear increases...??
Well, for one a <'09 FEH can't send power to a single wheel, no TC.
At a constant speed on a tight curve, I see no rear wheel torque.
"When increased handling or traction is required, the Intelligent 4WD System actively controls power" Driving perfectly straight and slow from a dead stop, do I need increased handling or traction???
"The majority of power is sent to the front wheels" I agree with that!
Old Oct 2, 2009 | 11:46 AM
  #104
wptski's Avatar
I'll take the percentage or whatever when needed but most of time it's unneeded.
The SG-II is nice but other the plugging in numbers, I'm clueless about it but have seen one guage setting affect a response from a command sent. That's why I question BillyKs statements of rear wheel torque at a steady speed. He has three SGs running at the same time and I think the 4WD PID is being skewed by something else or his vehicle has problems.
Old Oct 2, 2009 | 12:01 PM
  #105
wptski's Avatar
The SG-II shows rear wheel drop off slowly as you reach a steady speed but the scope shows a faster drop.
The workshop manual mentions using the 4WD ATC duty cycle for pinpoint tests. It's a valid PID. What I can deduct form the manual and the command, it is the 4WD module's address. I can only "assume" that it's the correct PID.
The only pinpoint test that I can reproduce is a tight turn <5MPH on dry had pavement. More the 20% is correct and I get that.
One test that I mentioned long time ago was to jack up the front end, one rear wheel and switch OFF the TC. You get all available torque to the one raised rear wheel.
Old Oct 2, 2009 | 02:28 PM
  #106
wwest's Avatar
No, I'm saying that upon acceleration at low speeds a portion of the torque is autmatically routed to the rear ONLY on the PRESUMPTION that traction might be low/poor. A pre-emptive "strike" if you will.
"...light, moderate or hard..."
At the instant, the VERY instant, you begin depressing the gas pedal the engine/transaxle control ECU does not know what your end "target" might be, it cannot predict the future. So the safe thing for the firmware programmer to do is assume the worse case and engage the rear drive immediately upon even the slightest initial depression of the gas pedal provided the transaxle is, is soon to be, in a low gear range.
And keep in mind that with DBW the rising of engine torque can be delayed until the rear drive is engaged or even until an appropriate downshift has completed.
No harm done if the traction is high and/or light acceleration is the target, and just maybe a few less injuries or even deaths.
At least that's the direction I would give my programming staff given the HIGH level of torque these hybrids can produce if the "target" should be HARD acceleration. The LAST thing a manufacturer wants is a preventable inadvertent loss of control for this reason.
Old Oct 2, 2009 | 02:53 PM
  #107
wwest's Avatar
This one puzzles me a bit, quite a bit(***). As a general rule a designer would NOT want any level of driveline windup or tire scrubbing in a tight turn resulting from driving both front and rear on a highly tractive surface.
In fact were this a R/awd system I would expect, wish for, ALL drive to be removed from the front in this condition.
I don't think so. Without TC to monitor the front brake sensor (tone ring) and compare it to the rear wheelspeed why/how would the rear drive clutch ever be engaged..??
*** A compromise, maybe..??
Yet another presumption, pre-emptive "strike".
FWD vehicles are HIGHLY subject to plowing/understearing should you encounter a slippery surface. Are they moving some of the HIGH engine torque at low speeds in TIGHT turns to the rear in order to allocate more of the front wheel drive traction to directional control to alleviate, lower, the potential for plowing/understearing..??
That's most likely what is done with the SH-AWD system but in that case virtually ALL of the engine torque can be re-routed to the rear in this circumstance.
Old Oct 2, 2009 | 10:04 PM
  #108
wptski's Avatar
TC controls torque to a individual wheel and the 4WD system controls torque between the front and rear, so you would have rear torque with the TC OFF.
Old Oct 3, 2009 | 10:17 AM
  #109
wwest's Avatar
But then other than low speed acceleration, what event "triggers", causes, the ATC to engage...??
With the old Aerostar it was rear wheelspin/slip that caused it to go from 30/70 F/R to 50/50 F/R. In reality it was simply a difference in F/R driveline roation rate but with the majority of torque to the rear there was a presumption of rear wheelspin/slip.
The Aerostar 50/50 mode was only sustained for about 20 seconds and then automatically went back to 30/70 and then awaited the next "event".
The FE's original F/awd system, in automatic mode, was much the same, FWD "ONLY", front wheelspin/slip would get you about 20 seconds with the rear driveline fully engaged.
With the FE/FEH, assuming it went into 4WD for some reason, event, what would result, as well it MUST, in the rear driveline "uncoupling"..??
Time period expiration..??
Old Oct 3, 2009 | 02:41 PM
  #110
wptski's Avatar
I have no idea how it's programmed, the dealer doesn't know and neither does their Tech HotLine! If I was still an active Ford employee, I maybe could get some contact numbers to call from our engineering people.
