Engine failure: Replace or rebuild
Old Feb 25, 2013 | 04:50 PM
  #41
GaryG's Avatar
Default Re: Engine failure: Replace or rebuild
Originally Posted by wwest
The ONLY mechanical differences between the standard Ford engine and the Atkinson cycle engine is the cam intake lobe timing and duration and the compression ratio of 13:1 vs ~10:1. The latter probably done via slight head milling or cylinder head "geography".
Both engines have the same head and block part numbers, so this indicates to me the pistons are what changes the compression ratio. The pistons must be of a pop-up design because the bore, stroke and valves are the same in both engines and heads.
GaryG
Old Feb 27, 2013 | 09:12 AM
  #42
wwest's Avatar
GaryG
Makes sense..
mikean16l
Sep 30, 2014 04:39 AM
Base430
Apr 18, 2013 09:29 AM
dlucarelli
Mar 27, 2011 02:18 PM
eak354
Apr 24, 2004 08:36 PM
