Electric motor not working
Old Jan 11, 2007 | 10:19 AM
greybird's Avatar
Default Re: Electric motor not working
Originally Posted by GaryG
This makes you the third person to claim that the ICE will shut down in freezing weather with the defroster on. I have stated from the first time I heard this that it makes sense Ford would program the FEH/MMH that way.
That's neat. Perhaps the software that shuts off the ICE looks at whether the A/C compressor is actually running, not whether it has been "asked to run" by one setting or another. If the defrost switch is on, the compressor is asked to run, but will not run if the temp is too low. If the software monitors whether the compressor is actually running, that makes it very reliable. This is a good technique for building reliable systems.
But of course I'm guessing. Don't you wish we could read the source code?
Mark
Old Jan 11, 2007 | 11:29 AM
GaryG's Avatar
Mark
Hi Mark
What we do know is that when the A/C switch is in the normal recir setting, the software will shut the ICE down along with the compressor. This does not mean the compressor clutch has been disconnected before the engine shuts down, just that the A/C compressor clutch has quit turnning with the engine. However, it does not make sense the engine would restart with the A/C clutch engaged. Bottom line, the PCM is remarkable how it controls these things at the same time. The PCM knows what position (command) the climate control switch is in, but yet it over rides that command when it senses a mode to go EV.
To bad I can't get my home computer to work this well!
GaryG
Curated Content Editor
Jun 18, 2014 01:00 PM
Tideland Prius
Sep 16, 2008 11:14 AM
sweetbeet
Nov 10, 2005 03:06 AM
Jason
Website Questions & Input
Jun 1, 2005 03:04 PM
