Dealer is trying to convince me to drain and fill cvt yearly
Old Feb 1, 2012 | 01:31 PM
hondarider90's Avatar
Default Re: Dealer is trying to convince me to drain and fill cvt yearly
Well, you referred to it at lub assuming you meant lube, I don't know nor do I have any reason to know much about the Prius so I based it not having ATF off of you saying lube which would be more of a gear oil generally.
Old Feb 1, 2012 | 03:17 PM
wwest's Avatar
ATF most generally means hydraulic functions are involved, not just lubrication and cooling. But the move aware from heavier viscosity oils for the benefit of FE improvement has "muddied" the water somewhat.
Old Mar 16, 2012 | 10:13 AM
Sphinx88's Avatar
I read the service manual and it never mentioned changing the CVT fluid anywhere...why??
Old Mar 31, 2012 | 12:48 PM
GatorJ's Avatar
It's supposed to be good for the life of the vehicle. The specified CVT fluid for a 2006 is Mercon ATF.
lincolnshibuya
Nov 22, 2011 12:41 PM
posmanti
Mar 3, 2011 10:45 PM
hyperhypomiler
May 25, 2009 11:54 AM
dangerkitty
Jan 7, 2006 08:42 PM
Stevo12886
Feb 5, 2005 02:23 PM
