Buying a Used Ford Escape
Old Oct 25, 2012 | 04:14 PM
  #41
wptski's Avatar
Imported from Detroit
Default Re: Buying a Used Ford Escape
Originally Posted by stevedebi
Some of the original advertising said it would engage at higher speeds "intelligently".
Not with good traction though. Advertising also said that it anticipates wheel spin too. How can it possibly perdict something before it happens? Maybe it has WiFi to get the latest weather report?
Ads also stated that the 2009 Ford Flex was the first to have DFCO(deceleration fuel cutoff). The 2009 Escape has it but I'm unsure if there were different versions and when it was first used. There was a patent for it used in a Ford Escort just to show how back it used in some form.
Old Oct 25, 2012 | 06:07 PM
  #42
It operates when one steps on the accelerator at all speeds, even during sunny and dry weather. It is designed this way. As someone has stated all along, the system is not so "intelligent".
Old Oct 26, 2012 | 04:51 AM
  #43
wptski's Avatar
You need to be more detailed in explaining what exactly you were doing at the time. It shouldn't engage at that high "constant" speed. I did forget that it will engage slightly for some unknown reason with moderate to heavy throttle from a constant speed.
HybridNovice
Oct 11, 2011 10:20 PM
Lia0821
Aug 20, 2007 06:19 AM
Methodical
Jun 25, 2007 08:05 PM
Conundrum
Sep 3, 2006 06:04 PM
philmcneal
Dec 6, 2005 02:28 AM
