Buying a Used Ford Escape
Old Oct 18, 2012 | 03:50 PM
elborak's Avatar
Cheapskate
Default Re: Buying a Used Ford Escape
Originally Posted by stevedebi
I realize that many folks buy the SUV to haul family stuff & etc (and that is my primary use as well), but I've always thought that an SUV should have the ability to drive all four wheels (in some fashion or another). It just seems right for the platform.
Pretty much my feelings as well. I knew I was giving up some MPG getting the AWD, but an SUV without AWD just doesn't make sense for my purposes. I can get better MPG than an Escape Hybrid if FWD is all I want.
Old Oct 19, 2012 | 06:03 AM
wptski's Avatar
Imported from Detroit
Originally Posted by elborak
That's one impressive placebo you've got there!
That system is refer to in Ford articles as a "On Demand" system but I fail to see the demand every time one leaves from a dead stop on dry hard pavement.
Old Oct 19, 2012 | 06:13 AM
wptski's Avatar
It was being invoked to varying degrees all the way up and down the mountain; it was not a constant percentage on the SG. I could also feel the front wheels slipping a bit.
By far the best real life situation I have ever read about the system. Did the TC kick in as well?
I have a very long enterance ramp to a x-way in my area and while coasting, I always notice it will engage for a split second, just a few percent.
BTW: The 2013 Escape has a dash icon showing torque to each wheel. Since the Ford's 4WD/AWD can only devert torque between the front/rear, I'm not sure how it can show each wheel unless they mean TC. I've seen one owner complain that it shows nothing!
Old Oct 19, 2012 | 08:08 AM
elborak's Avatar
Cheapskate
There's a big difference between saying the system activates at times that seem pointless and saying that the system does nothing and any perceived advantage is a placebo affect.
Old Oct 19, 2012 | 09:17 AM
wptski's Avatar
I used the word "placebo" because if one believes the ads, articles even from Ford Powertrain Specialists you think that you have one hell of a system but you don't!
One of those Specialists wrote that under heavy throttle the system all torque to the rear so the front has more steering control. You can mash the pedal to the floor and get a bit over 30%.
A Ford site even had a graphic showing torque being deverted side to side through as "S" curve road. That was pulled since it don't work that way at all.
Old Oct 19, 2012 | 03:16 PM
stevedebi's Avatar
No TC on the 2008 model so far as I know... so no, it did not kick in!
Old Oct 19, 2012 | 04:46 PM
  #27
wptski's Avatar
That's right, IIRC that was added in the '09MY Hybrid.
Old Oct 20, 2012 | 12:35 AM
  #28
elborak's Avatar
Cheapskate
Watched my ScanGauge on the way home from work. Under acceleration I regularly exceeded 30%. Highest I noticed was just over 63%.
Several of us have now disputed your claims that the system does nothing (the definition of a placebo). We've backed them up with real experience driving the vehicles.
You clearly have a chip on your shoulder regarding Fords AWD system, and don't let facts get in the way of your argument. I'm done.
Old Oct 20, 2012 | 06:58 AM
  #29
wptski's Avatar
If you get 63%, your using the original coding by DesertDog/CarlD and not the changes he made later on.
I never said that it did nothing. I said that it doesn't do what ads leads one to believe.
Your a noobie, I'm not but I don't own a Hybrid but have an Escape with 4WD which brought me to this forum after seeing some pictures of SG screens posted elsewhere by a user. That's back when I belived it was a "On Demand System" and the pictures showed differently.
I put lots of effort into learning how the system really works and if you care to learn something too, you can read the whole thread here: https://www.greenhybrid.com/discuss/...uage-ii-21592/.
Old Oct 20, 2012 | 12:12 PM
  #30
GatorJ's Avatar
It's a placebo effect. If you had a ScanGuage II to monitor rear wheel torque you'd really see when it engages. It's more hype than fact.
Here's an interesting video comparing different systems including the Escape: http://www.youtube.com/watch?v=ktoGVBR4op4
Nonsense...you are knowledge base challenged on this issue.
