Air deflectors-good or bad for FE?
Old Jan 7, 2008 | 07:20 AM
nicst47's Avatar
Default Air deflectors-good or bad for FE?
Are the window air deflectors considered goo or bad for FE?
Old Jan 7, 2008 | 08:50 AM
Default Re: Air deflectors-good or bad for FE?
Anything that makes your car wider or taller is bad for Fuel Economy.
More so at higher speeds.
If you like them tho... go for it. Your MPG loss will probably be too small to notice, and will proably "cost" you 1 gallon extra per year... or less....
-John
Old Jan 7, 2008 | 09:38 AM
nicst47's Avatar
-John
For some strange reason, I thought they might actually help FE by blocking wind flow when the window is opened.
Old Jan 7, 2008 | 11:08 AM
econoline's Avatar
I have them on my FEH, with no observable change in FE. I also removed the roof rack and installed the factory tracks, again no observable change to FE. Probably same with mudflaps, all these things do affect FE but not enough to be noticeable in normal street driving. However tire pressure does make a measurable change in FE.
Old Jan 7, 2008 | 11:18 AM
nicst47's Avatar
Thanks Don.
chimemaker1
Jan 25, 2008 07:48 AM
DBS
Jun 20, 2007 04:22 AM
leepark
Nov 8, 2006 09:50 AM
dbennettya
Apr 14, 2006 12:26 PM
