Accuracy of MPG Readings
Old Jul 12, 2006 | 12:27 PM
  #31
Pravus Prime's Avatar
Prof. of Hybridology
Default Re: Accuracy of MPG Readings
Everyone, take a deep breath, relax.
....And it's tank average over the last data points since the reset...
Old Jul 12, 2006 | 12:47 PM
  #32
VietVet'67's Avatar
Escape Hybrid Enthusiast
I thought that was one of my thoughts - back at YA
All is Cool!!
Old Jul 15, 2006 | 07:43 AM
  #33
indnchf's Avatar
We'll after continuing to watch the white avg line for a few more tanks, I guess I have to back away from the 15min average statement, and lean towards what others are saying about the tank average.
What has confused me is how quickly this number can change with very little mileage change.
I've been used to my Garmin GPS unit for the past 3 years. It gives you an average driving speed. At first this average changes rapidly based upon your speed. But once you get over 400 miles (or one of my 3,000mile one way cross country trips), To go from a 56.5 mph avg to a 59mph avg while driving on the freeway the whole time at 60-70mph takes all day if it budges at all.
Now this tells me that the MPG figures must be very Volatile unlike avg mph figures, and just a slight change in driving characteristics can change your average drasticly.
Of course if the NAV would retain more data it should become less volatile.
What's the longest someone has gone without resetting the NAV white line average? Did it become less volatile over time? Or do the majority reset it per tank?
Gary
Old Jul 15, 2006 | 09:52 AM
  #34
GaryG's Avatar
It does not appear there is anyway to connect to the Navi to determine the data average information. The best way I can think of is going thru the manufacture for an answer. It all seems to point to a hour clock IMO. For instance, yesterday the winds here were favorable for some good MPG. I presently have 20.7 hours on my tank according to the SG, but I was able to pull 1.7 MPG Navi average over the SG tank average yesterday. Both gauges were reset at fill-up. According to the amount of fuel used from the SG tank reset, the Navi was off by 1.5 mpg average because it had dropped data on the present tank. The SG showed about 6 miles less than my trip OD which I went by. That accounts for the .2. mpg average less than the SG.
Gary, I would be completely in the dark about the accuracy of the navi without the SG to compare it with. There within a few tenths average after reset untill the SG hits between 10 and 20 hours driving. I and other's here, estimate half the data is being dropped once the navi memory is full. In the example of my driving yesterday, I had great MPG and the navi increased faster compared to the SG. The oposite will happen if I get poor MPG, the navi will drop faster and go below the SG reading. The fact is, unless you have some drastic changes in MPG near the time you fill up, both gauges should read within a few tenths. This is why my conclusion is the navi and the message center averages are better than what you get at counting the gallons at fill-up.
In my opinion, take the average on the navi or message center and record them as your true reading unless you have drastic changes high or low just before fill-up. If you want to know your true MPG at all times, get a SG or something that can carry all the memory of the entire tank.
GaryG
sward
56
May 17, 2008 09:52 AM
rfortson
Sep 11, 2006 07:44 AM
Orcrone
Aug 11, 2006 06:34 AM
kenny
Nov 24, 2005 09:20 PM
EricGo
Nov 7, 2005 12:59 AM
