2009 FEH P0A7C Electronics over temperature
Old Dec 9, 2020 | 12:41 PM
Default Re: 2009 FEH P0A7C Electronics over temperature
I'm hoping it's either bleeding/air problem or a sensor that is not reading correctly anymore. I've worked on so many kinds of equipment (including big industrial inkjet printers) that rely on temperature sensors to give the "all clear." One of them starts reading incorrectly through its range, isn't connected properly, has something clogging it or obstructing it, etc., and the computer shuts the print engine down. Then you have to find the bad sensor, run the test mode, put a meter on it, etc., and figure out which one it is. In other words I'm hoping it's something you can isolate and swap out. I wish I knew more about where the MECS system gets its inputs.
Old Dec 9, 2020 | 07:35 PM
econoline's Avatar
Originally Posted by Jason1234
Its hard to tell when it is going to come on.
Are you monitoring MeT (motor electronics temperature)? When my MECS pump was going out I could see the MeT rising on the Scangauge as I was driving and knew that shutdown was imminent. MeT is a good parameter to monitor for MECS problems. I forget what the trigger temperature was but should be easy to find in the forum.
Old Dec 11, 2020 | 10:56 AM
fglaustin's Avatar
i am watching this also - since i have an 09.
one of the most replaced electronics parts on an automobile is the coolant temp sensor;
but since that has been replaced - well i dont know.
Old Dec 11, 2020 | 01:52 PM
Hippo the Hybrid's Avatar
If the MECs pump is working for sure and you have bleed the air at least 3 times, you might want to study reflashing the PCM and/or other computers with the latest editions. Something you might be able to to yourself with a short FORD subscription and connected laptop or you could take it to a hybrid safe Ford dealer. Perhaps publish the Forscan output for the dates on all the computers and members with FORSCAN can see if you are running the latest software.
ddderek
Oct 18, 2021 03:57 PM
german_cargo
Sep 10, 2019 10:52 PM
08hybridok
Aug 2, 2014 01:59 PM
Bill Winney
Dec 4, 2013 11:23 AM
Brandon Williams
Nov 2, 2012 11:18 AM
