2008 Navigation Package
Old Apr 11, 2007 | 03:28 PM
DavidH's Avatar
2008 Escape Hybrid Owner
Default Re: 2008 Navigation Package
Does anyone with an 08 have tweeters in the window pillar sails? If not, where are the 7 speakers? I have a speaker in each of 4 doors, and one woofer in the rear.
Old Apr 11, 2007 | 06:32 PM
cngrevolution's Avatar
David. what dealer did you have this done? I am in the dallas texas area. I am about to buy 2 of these escapes. one for me and one for the wife. they have the colors and options we want except for the nav syatem. the dealer is saying they can't add it and I was suspect that they did not know what they were talking about. Maybe you could give me a name and number of someone they could speak to at your dealer to explain how it might be done. Also what did they charge you for that? did they just charge you the same price as if it was an option on the car. or did they charge extra because they had to do all that r & r? does the nav system show the hybrid current flow? thanks for any info!!
Alex
Old Apr 11, 2007 | 06:36 PM
also the tweeters are in the "a" pillars near the bottom of the windshield. I have had fords for many years and more times than not they are set up to be plug and play. Meaning theres a good chance that if you remove one of the pillars and look to see if there is a plug set there, if so then you could just order new pillars and the speakers and just plug them in and your done.
Old Apr 11, 2007 | 06:39 PM
one other question david. when they put in the nav system does your display up at the top now show the time and date, outside temp and compass reading?? as well as the ac temp for driver and pass?? thanks!
Old Apr 12, 2007 | 04:22 AM
WaltPA's Avatar
Originally Posted by DavidH
And, if the premium sound has 7 speakers, they must not have separate speakers grilles. I can only find 5 speakers!
At least for the '07 models, the Nav system when ordered as part of the "package" included 7 speakers. When order as a stand alone option, it included only 4 in-door speakers.
Old Apr 12, 2007 | 04:25 AM
WaltPA's Avatar
Being able to retrofit in the Nav system must be something totally new for the '08 models. One couldn't on the '07 and older models because the Nav system needed to tie into the hybrid system, and therefore required rather unique wiring harnesses which weren't on the non-Nav hybrids.
So, I would not be so hard on your dealer.
Old Apr 12, 2007 | 05:56 AM
  #27
DavidH's Avatar
Alex
Contact: Jim Shaw, Service Advisor
Heller Ford, Escondido, Ca, USA 92029
+1 (800) 427-3585 x308
They charged me the difference between the Audiofile option and the NAV option. But, that may not be their normal deal.
I will look for the current readout next time I drive the car and get back to you.
Did you see an 08 with tweeters in the windshield pillars?
Old Apr 12, 2007 | 06:07 AM
  #28
GaryG's Avatar
Good point Walt.
Here is a link that some of you may not have seen that speaks on some things about Vehicle Speed Sensors that the navi is connected to in section 2-2. There is a lot of other good information on do and don't when installing or disconnecting things on the '06 FEH/MMH. It's long, but some areas are very interesting.
https://www.fleet.ford.com/showroom/...iers_guide.pdf
GaryG
Old Apr 12, 2007 | 05:04 PM
  #29
DavidH's Avatar
The 2008 NAV display shows the direction of current flow, but not the Amperage.
Old Apr 12, 2007 | 06:53 PM
  #30
Nward's Avatar
Just ordered a 08 FEH. I did not order the Nav as the price was to much.
If any of you have upgraded your system?
What system did you go with?
Since I have no nav. If any one would like to sell me a OEM for the 2008 FEH?
Let me know.
