2008 FEH Transmission acting strange
Old Apr 10, 2011 | 09:09 PM
buzz lightyear's Avatar
Default Re: 2008 FEH Transmission acting strange
Originally Posted by GaryG
My '09 FEH RPM does not get that high either but the '05 has always had a problem with high RPM's. I came up with the term fake shift back in 2005 on this board to allow the RPM's to drop back down to re-accelerate.
When E10 was mandated here in Florida the problem got real bad trying to accelerate without the RPM's getting out of control. This is a big reason the '05 had such a big decrease in MPG on E10. Programming may have changed in the '08 FEH, can anyone else confirm what I'm talking about?
GaryG
My '08 never goes above about 4200 rpm even accelerating up a hill. But then again, I usually back off and slow down once I see the tach crossing the 4.
Old Apr 11, 2011 | 05:30 AM
colchiro's Avatar
Maybe that's why?
I don't think mine goes much over 3-3,500, (from memory), but that probably just my driving.
Old Apr 11, 2011 | 06:19 PM
wilcal's Avatar
A few days ago, while playing with my 06 FEH I got
it into a situation where the HVBATT was easily
at 70% as displayed by the NAV system. So
essentially there was no more space to put energy.
I then found myself going down a rather steep and
long hill so I put the "gear shift" lever ( it's
not really a gear shift lever ) into the "L"
position. The rpm of the engine immediately
rose to at least 4000 rpm maybe a little higher.
I think what happened here is the computer figured
it had no regen braking left in the battery and
told the eCVT to put all the breaking load back
into the ICE. Which drove the rpms up to the high
level.
Old Apr 20, 2011 | 07:26 PM
What you saw there was the Negative split mode. That's the equivalent of downshifting to use engine compression. They've programmed this precisely so that when you are slowing down and the battery is topped up, the energy goes somewhere.
cobia265
Jun 28, 2015 05:04 PM
twolostminds
Nov 17, 2014 06:23 AM
us035976
Jan 17, 2014 02:29 PM
Gruson
Mar 13, 2009 06:00 AM
Tarran
Mar 21, 2008 12:33 PM
