2007 Ford Escape Hybrid won’t start ($100 to whoever gives me the right solution)
Old Sep 25, 2021 | 04:53 PM
  #31
Default Re: 2007 Ford Escape Hybrid won’t start ($100 to whoever gives me the right solution)
Originally Posted by NDunfiltered
Yeah but he’s also the guy that sounded very skeptical about allowing his shop work on hybrids because he doesn’t have a hybrid specialist and he also caught himself and wouldn’t schedule with me yet because he needs to speak to his head mechanic who wasn’t in at the time. That price very quickly could change and not only that - they don’t have availability for almost 4 weeks (I’m in NJ and shops are still playing catch up from all the flooding weeks ago.)
I really would like this **** HV push button to work and power the HV battery just enough to get it started. I’m not sure if the battery hits a certain threshold it disables the push button?
Also: There are people who have encountered cars with the push button but it doesn't work because they have tried to SWAP THE BATTERY AND BCM from a later year that DOES NOT HAVE THE BUTTON. So obviously the button will not work in that circumstance because the circuitry in the BATTERY ITSELF is not there.
Old Sep 25, 2021 | 04:55 PM
  #32
NDunfiltered's Avatar
Originally Posted by AlexK
Once the battery has discharged to a certain point the NiMH chemistry changes and it can take a long time with the charger SKeith recommends to get it to bounce back and accept a normal charge again. This is from what I have read, not experienced directly since it has never happened to mine, but I see no reason to disbelieve it. That may be why you are having problems with the button. As far as I know there is no "disabling" of the button, but people DO recommend trying it several times with an *auxiliary* vehicle ALSO attached to the FEH battery via jumper cables. You might try that. Get another good car that is running, hook up jumper cables between that car and the 12V FEH and hit the button. Then wait. Then hit the button. Then wait. Then hit the button. Then wait. Then try to monitor the voltage and see what you have and see if it is improving.
That's the best advice I've got, otherwise you're looking at the guy you're talking about. I am sure SKeith is correct when he talks about the NiMH chemistry change that causes the battery pack to be "reluctant" to accept a baseline charge until that evens out, and that can take time and effort. Good luck!
Also make sure the "light" on the button lights up and how long it stays lit before it shuts off. Make sure it's actually working!
Yeah — I mentioned it before but that light hasn’t been working since this go around of the car not starting. It used to work but now it refuses to light up, which is making me question what happened to make it stop working. My other concern is I don’t want to continue to burn money away having this towed to a dealership to have them charge it and then find out it’s not the issue and then have to get it towed back and just keep cycling through this. So I’m trying to get more information and knowledge in hopes someone can help guide me the right way so I don’t waste money excessively. Hence offering $100 to whoever leads me to the direct source of the issue and it being fixed.
I’m all about efficiency. I can’t stand being wasteful - whether it’s with time or money.
Definitely appreciate all the advice. I’m going to have to find a laptop to plug this thing into though.
Old Sep 25, 2021 | 05:07 PM
  #33
If the button doesn't work and you KNOW the battery pack and its associated hardware are internally correct for the year of the car, then you suspect the button or the wiring has gotten munged somehow. It's also possible the little light has blown out! I don't even know if it's an LED or an incandescent! Maybe the connector fell off!
At that point you're looking at finding a button that works or getting the battery charged by yourself or someone else. Always begin with the cheapest fix and work up from there.
Old Sep 25, 2021 | 05:16 PM
  #34
A part of me has questioned is the HV battery a lost cause and maybe that’s why the push button isn’t working. I wish there was a clear cut way to figure that out because that would save me money since I know for a fact I’m not putting a replacement HV battery in this vehicle. Would mean I’m spending significantly more than I want to and at that point I’d just invest it into another vehicle.
I kinda was doing that. First I started by replacing the ignition switch and checking all the fuses/relays. But now I’m reading there are computers and relays for the HV, and I don’t even know if I want to play with all that.
Worst part is, I bought this just last summer and couldn’t use it until practically fall because MVCs were all closed in NJ and I couldn’t get it registered. So I bought it at 39K miles and currently it’s at 41K miles and it already has given me all these headaches. Had I know hybrids were this much of a pain in the *** I would have just paid more money and got a different car.
Old Sep 25, 2021 | 05:17 PM
  #35
Also, just reading between the lines here - and correct me if I'm wrong - it sounds like you've got one heck of a badly flooded 2007 FEH on your hands. I have friends in NJ and I've seen the pictures of the underwater Scubaseball stadium and train station near Bridgewater.
Old Sep 25, 2021 | 05:20 PM
  #36
No. I bought the car in NY and my area didn't get flooded. Surrounding areas like Bridgewater and plenty of other areas in NJ were flooded heavily though so shops and dealerships out here are being bombarded.
Old Sep 25, 2021 | 05:36 PM
  #37
Well I truly wish you the best of luck with it and please make sure you don't try to attach any kind of sidecar to it. I know that a lot of cars there have become submarines and even the dealerships aren't accustomed to working on U-boats.
Old Sep 25, 2021 | 05:48 PM
  #38
https://www.youtube.com/watch?v=QhjBlPucpd0
Not getting the sidecar reference. And yeah - I spoke to several dealerships and they’re talking about how they don’t have room on their lots because insurance companies are taking forever to help them move forward with the cars that were flooded out.
Old Sep 25, 2021 | 06:52 PM
  #39
I have to look at that, but SKeith's thread about it is not hard to follow, I'm a noob too, and I'm building one (even though I don't need one yet) this winter. It's really pretty simple, it's an off-the-shelf device and some wiring and diodes. It'll be fun to put it together and everyone here knows it works. Then you stash it in the car and have AC powered emergency charging available any time, all the time.
I'll look at your link later tonight.
BTW - f**k this company. I sent them an email asking questions about their product and about how easy it is to set up and the guy was just completely rude and disrespectful, being all arrogant like I was wrong about asking him regarding the ease of use. I told him it wouldn’t make sense for me if it’s difficult to use and he goes on a tangent about how they’re a world renowned company and never have any in stock so they don’t need my business and whatnot. Yet they have 11 followers on Instagram and are scared to market a product in fear someone’s going to steal their “precious idea” to have anywhere for me to see a demonstration on the product or how easy it is to use. hahaha. I’m literally going to create a Yelp for their company just to write a negative review and screenshot him telling me to **** off just for question how credible the product is. XD
Old Sep 25, 2021 | 09:10 PM
  #40
econoline's Avatar
  • The Forscan Android app will do everything you need at this point, skip the laptop.
  • The Rebalance function has nothing to do with this problem, maybe later when you get it running.
  • In the Forscan app, add State of Charge and HV battery voltage to the Dashboard so you can read them. What are they?
  • The purpose of the ammeter on the 12v battery is to confirm that the HV jump start function isn't working & it's not just the LED burned out. Is there any change in current when the button is pressed?
  • All of the DTC codes you see with Forscan can be cleared with Forscan. They are stored in memory but maybe not relevant to the problem now. I would record them all, then clear them, and see what codes come up now.
