2006 FEH and infrequent EV mode
Old Jun 18, 2018 | 08:28 PM
91Bear's Avatar
Default 2006 FEH and infrequent EV mode
I have a 2006 FEH and it's not dropping into EV mode as often as it used to. After the initial warm-up, it will, but as you drive it it stops going into EV mode. Mileage is pretty lousy - especially in stop and go traffic. I can hear the fans on in the back. I don't get any error codes from my bluetooth OBD unit. While driving, I can occasionally hear a clunk from the front end. It's almost as if the electric unit wants to assist but can't. I don't know. Maybe it's the blend door but it sounds like it is coming from the front.
Any ideas? I have 203,000 miles on it.
Old Jun 18, 2018 | 08:40 PM
Default Re: 2006 FEH and infrequent EV mode
NiMH batteries lose capacity over time, heat and use. Eventually, it will reduce the usable capacity of the battery to where the efficiency is impacted. not sure about the clunk, but the rest of it sounds like typical battery deterioration.
Old Jun 19, 2018 | 11:45 AM
91Bear's Avatar
Well, it worked fine a couple of weeks ago - until my A/C got low on coolant. I recharged it but the EV is not working like it should.
If the batteries were low, wouldn't the system check tell me so?
Old Jun 19, 2018 | 11:47 AM
No. Unless certain trouble code criteria are met. A battery can have as little as 30-40% of its rated capacity and perform normally in most situations.
If your rear A/C isn't cooling the battery as effectively, the increased battery temperature causes the car to decrease battery utilization.
Old Jun 20, 2018 | 09:27 AM
91Bear's Avatar
How do you know if the blend door is working (or not)?
Old Jun 20, 2018 | 09:35 AM
It generally codes if it doesn't.
Have you tried Forscan on the following:
PC with a MiniVCI cable
PC and bluetooth adapter
Android and bluetooth adapter
Most "run of the mill" OBDII options including Torque are inadequate for the FEH.
Old Jul 1, 2018 | 09:08 PM
91Bear's Avatar
Forscan is giving me P0A81-60 and P2521-FF/P2524-FF.
I assume the last two are because the air conditioner was on when I ran the test.
P0A81 seems to indicate the fans for the battery pack are not working, even though I can hear them.
noreception
Jul 26, 2023 09:39 PM
Shane Carr
Mercury Mariner Hybrid
17
Aug 30, 2021 12:25 PM
pmstirling
Aug 20, 2020 09:39 PM
Marik
Apr 10, 2017 11:59 PM
