2005 vs. 2007 Escape hybrid mileage
Old Jul 26, 2010 | 02:05 PM
colchiro's Avatar
Default Re: 2005 vs. 2007 Escape hybrid mileage
Ok, same drive type, should be similar mileage.
Old Jul 26, 2010 | 02:22 PM
GaryG's Avatar
Sounds like you may have a overheating problem and I would check the electronics coolant pump to see if it's running with the Key On engine Off mode. If the A/C is cooling properly you should be okay with it cooling the battery. The only thing left would be a bad HV battery fan which there is a thread about that here near this one. These things will all cause short or no EV runs.
GaryG
Old Jul 27, 2010 | 05:28 AM
dae06's Avatar
Thanks GaryG, I'll look for that post.
There is one thing that was a little different between the two vehicles. When we had the 2007, we always heard a faint high pitched whine (in HEV mode). The owners manual said this was normal. We do not hear this in the 2005. Could that be something to look into?
Old Jul 27, 2010 | 06:05 AM
GaryG's Avatar
I hear that faint high pitched whine in EV only in certain outside lack of noise and slow speeds. I don't think your problem is related to that though. Your tires could be drowning out that hard to hear noise.
Here is one thread about the fan problem: https://www.greenhybrid.com/discuss/...nty-not-24766/ There are a few more here if you research a little.
GaryG
chartierpw
Ford Motor Company
May 8, 2024 11:01 AM
MrFixit1328
Sep 16, 2022 06:04 PM
mppkll
Jul 1, 2014 05:16 AM
hugoland
Feb 4, 2008 07:21 AM
08Mariner
Oct 1, 2007 04:07 PM
