2005 FEH Stop Safely Now
Old Dec 25, 2020 | 12:31 AM
RickySpanish2021's Avatar
Exclamation 2005 FEH Stop Safely Now
Ok so this is not just another SSN thread. I have read and tried most of the common solutions already .
Lets get right to it . A squirrel chewed into the HV wire harness that runs across the engine from the DC/DC converter to Continuous variable transmission . Luckily only one of the wires was chewed through, the red one. Once I noticed this I put a bread tie between the two ends that where severed . I was then able to start the vehicle right up . So, I went to Auto Zone and got some 16g wire to replace the bread tie. This seemed to work , as I was able to drive around the block with not obvious issues . However , a day later I, went out to start the vehicle and got the now dreaded STOP SAFELY NOW prompt. Since then I have replace the DC/DC converter , removed the 16 g wire to connect the end directly together , and checked the MECS pump.
Symptoms:
SSN
No power to the Mecs pump
?? no ground two the Mecs pump relay ?? not sure about this one
Codes as followes
TCM - Transmission Control Module:
P0A0A-FF, High Voltage System Inter-lock Circuit
U0100-FF, Lost communication with the (PCM)
P1A04-FF, Generator Shutdown Circuit
P0562-FF, System Voltage Low
P1A03-FF, Drive Motor A Shutdown Circuit
EPS- Electronic- Controlled Power Steering:
U1900-FF, (CAN) Communication Bus Fault - Receive Error
B1318-FF, Battery voltage Low
IC:
B1318-20, Battery voltage Low
U1900-60, (CAN) Communication Bus Fault - Receive Error
GEM:
U2023-60, Fault Received from External Node
BCM:
P0A27-60, Battery Power Off Circuit
P0A0A-20, High Voltage System Inter-lock Circuit
U0101-20, Lost communication With The (TCM)
P0A95-20, High Voltage Fuse
U0100-20, Lost communication with the (PCM)
P0AA6-60, Hybrid Battery Voltage System Isolation Fault
P0A8D-20, 14 Volt Power Module System Voltage Low
B1016-20, Jump Start Control Module Fault
I have check all internal and external fuses, none are blown. I checked relays, they are good, but the fuse box where the relay sits seem to not have ground for the first two furthest from the fire wall. I put a multimeter on the orange (high voltage) wire that runs across the engine , it doesn't have any power coming out
New :
Car battery and DC/DC Converter
PLEASE HELP !! slowly losing my mind
Old Dec 25, 2020 | 01:15 AM
Default Re: 2005 FEH Stop Safely Now
12v?
Old Dec 25, 2020 | 02:15 PM
Sorry I don't understand what you are asking
Old Dec 25, 2020 | 03:52 PM
How's your 12V battery. Lots of codes in there that occur with low 12V.
Old Dec 25, 2020 | 11:13 PM
It is good, just replaced it and had it tested by auto zone
Old Feb 4, 2024 | 10:58 AM
dgeatdg's Avatar
Ever figure this out?
accent2010
May 8, 2022 06:45 PM
TheMechanic84
Oct 16, 2014 06:17 AM
408ttop
Sep 20, 2012 05:40 PM
CyberBiker
Oct 19, 2008 10:48 AM
