1200lb cargo load
Old Apr 19, 2010 | 06:41 PM
Default 1200lb cargo load
I could have carried another five bags of wood pellets without any issue.
Old Apr 19, 2010 | 08:17 PM
wptski's Avatar
Imported from Detroit
Default Re: 1200lb cargo load
GVW-curb weight=?????
Old Apr 20, 2010 | 04:50 AM
glennb's Avatar
Red face Re: 1200lb cargo load
Alright! Now that's how you put this truck to use!
[Glad you didn't include any complaints about dash rattles or tire noise while you were delivering this load.]
Old Apr 20, 2010 | 06:59 AM
wptski's Avatar
Generally speaking, it's probably a 1/2 ton but knowing the curb weight, you can figure exactly what your load limits are. Of course, limits are clearly ignored here anyway!
Old Apr 20, 2010 | 01:22 PM
colchiro's Avatar
I'm waiting for the side view pic...
Old Apr 20, 2010 | 02:54 PM
As found elsewhere, you weren't expecting the Toyota look:
Here is the side view with a 1000lb load.
Have a good day.
Old Apr 20, 2010 | 04:36 PM
wptski's Avatar
I found that the GVW on a '05 FEH is 4680 lbs. and the curb weight of a 4WD '05 FEH is 3792 lbs. Using that info the max vehicle payload should be 888 lbs.
Old Apr 25, 2010 | 06:38 PM
However, the owner's manual says the payload is 1,000 pounds, including passengers of course.
Old Apr 25, 2010 | 07:28 PM
wptski's Avatar
Actual payload is GVW-curb weight. Since when are you following the manufacturer's suggestions, considering what I've read about your towing practices??
Old Apr 25, 2010 | 08:07 PM
colchiro's Avatar
We do what we have to do with what we have. I hauled 100 car and truck batteries in my Dad's 1/2 ton Ford pickup one time for 50 miles. I know I didn't air up the tires before and we know car batteries are heavy, let alone tractor and semi truck batteries. That truck was squatting and since it had a topper on it and I had to load all 100 batteries in a bent-over position, I was hurting.
