1200lb cargo load
1 Attachment(s)
Attachment 3038
I could have carried another five bags of wood pellets without any issue. |
Re: 1200lb cargo load
GVW-curb weight=?????
Alright! Now that's how you put this truck to use!
[Glad you didn't include any complaints about dash rattles or tire noise while you were delivering this load.] :P |
Generally speaking, it's probably a 1/2 ton but knowing the curb weight, you can figure exactly what your load limits are. Of course, limits are clearly ignored here anyway!
I'm waiting for the side view pic... :P
3 Attachment(s)
As found elsewhere, you weren't expecting the Toyota look:
Attachment 3035 Here is the side view with a 1000lb load. Attachment 3036 Attachment 3037 Have a good day. |
I found that the GVW on a '05 FEH is 4680 lbs. and the curb weight of a 4WD '05 FEH is 3792 lbs. Using that info the max vehicle payload should be 888 lbs.
However, the owner's manual says the payload is 1,000 pounds, including passengers of course.
Originally Posted by gpsman1
(Post 222002)
We do what we have to do with what we have. I hauled 100 car and truck batteries in my Dad's 1/2 ton Ford pickup one time for 50 miles. I know I didn't air up the tires before and we know car batteries are heavy, let alone tractor and semi truck batteries. That truck was squatting and since it had a topper on it and I had to load all 100 batteries in a bent-over position, I was hurting.
