'09 FEH Techniques
Old May 31, 2009 | 09:33 AM
  #31
rmcmast's Avatar
Default Re: '09 FEH Techniques
Originally Posted by GaryG
Do you feel a small jerk as the FEH goes from fuel-cut at 40mph to EV? Many times I have to be going in the upper 40's mph or higher in "D" to start fuel-cut but when I get it I coast right into EV at 40mph. Of course I shift to neutral once the tach starts to drop into EV. Most of the time my SoC is far below 47% and that's why I don't think it is a condition for fuel-cut. My fuel-cut is from coasting on flat roads because I have no hills. Partial fuel-cut with closed-loop even under 40mph also gives me much better Instant MPG numbers coasting in "D" than my '05 FEH.
GaryG
Are you asking if I feel a jerk transitioning to EV when I'm not getting fuel cut? I'm not sure, but I'll check. All transitions to/from EV are so much smoother than my 2007 FEH, I barely notice them unless I'm looking at the gauges.
I'm sure you're right about SoC below 47 not being the determining factor. This does not happen as often as it used to (not getting fuel cut). Could temperature or break-in effect this? Another difference is the service I had a couple of months ago for the engine light (both o2 sensors and exaust manifold were replaced).
--Rick
Old May 31, 2009 | 02:15 PM
  #32
rmcmast's Avatar
I noticed the same behavior this afternoon, although the SoC threshold was 46 or so. Less than 46, no open loop when coasting above 40mph (was doing 40-50). I did let it glide down into EV with closed loop a couple of times and felt a slight jolt when it dropped into EV.
May be something else going on too, but it happened 3 or 4 times as I bounced between 44 and 48 or so SoC.
-- Rick
Old May 31, 2009 | 04:58 PM
  #33
GaryG's Avatar
-- Rick
Now we are on the same page with the slight jolt I'm seeing in the transition from fuel-cut to EV at 40mph or so. I'll watch the 46% Soc requirement and post my findings. At fill-up I changed my fuel-cut settings to 16 on one SGII and 17 on the other SGII and you can see my mileage in the mileage log only at CleanMPG.com:
http://www.cleanmpg.com/index.php?page=garage&displayunits=MPG(US)&viewcar =2612
GaryG
Old May 31, 2009 | 05:29 PM
  #34
wptski's Avatar
Imported from Detroit
Gary:
Is that actual MPG or what the SG shows?
Old May 31, 2009 | 06:07 PM
  #35
GaryG's Avatar
Originally Posted by wptski
Gary:
The SGII was way off from MPG but it is adjusted much better now. That is actual MPG I pumped from the time my FEH rolled off the assembly line and tested. In other words the lifetime mileage on my OD is divided by the gas I pumped into the tank. This is as much actual as it gets with no BS from the time it was first started at the factory.
GaryG
Old Jun 1, 2009 | 08:29 AM
  #36
wptski's Avatar
The 3.0L V6 in the '09 Escape must have got fuel-cut like the 3.0L '10 Fusion which means you are a lucky dog. Now, did you also show 9,999 Instant MPG on your SGII? For some reason even my SGII does not show Open Loop and 9,999mpg 100% of the time when coasting above 40mph. Rick has posted that he does not get fuel-cut unless he has a SoC above 47% which I have not seen as a requirement yet.
GaryG
Gary:
Driving today, anytime over about 40mph where it seems to go open loop while coasting, it went 9,999mpg every time. As soon as brakes are applied, it goes closed loop.
Old Jun 1, 2009 | 12:48 PM
  #37
Hmm.... in my 2005 IIRC I can hit the brakes ( over 40 MPH ) while in open loop / fuel cut and it stays in fuel cut. ( such as when going down a very steep hill )
Old Jun 1, 2009 | 04:11 PM
  #38
GaryG's Avatar
Gary:
It sounds like Ford had to design the software so the brakes would not cause a problem with the transmission holding the engine idle during fuel-cut. Our eCVT uses regen when applying the brake pedal but I'll be sure and check it out latter.
Today I was on I-95 doing between 60 - 65mph and I did a lot of fuel-cut during decel and I noticed it took ~3 seconds to go open loop any time I let off the gas pedal. I think the idle at that speed was to high for my SGII fuel-cut setting to read 9,999. I'm at 16 and 17 now and maybe I need to go 18 because I did not get above 200mpg or so when I went open-loop at that speed.
GaryG
Old Jun 2, 2009 | 08:32 PM
  #39
wptski's Avatar
I've been told that fuel cut has been used for years by Ford on some of its gas engines and it's nothing new. No real way to double check that as I don't own another older Ford product!
Googling showed patents from Ford going back 1998 and 2000. Even mentioned a 2.0L 1998 Ford Escort. Early systems had problems and the latest patent explains a very complex system of engine controls for fuel cut.
Old Jun 3, 2009 | 10:49 AM
  #40
MyPart's Avatar
I am positive that my '95 Mustang has fuel cut after you're off of the throttle in a deceleration scenario. The engine will change tone approx. 1 second after full throttle release and deceleration is more noticeable. This change in tone is the same as when you turn off the ignition while decelerating (like you would if your brakes didn't work and you needed to use the engine to stop). Staying slightly on the throttle (but still slowing without the brakes) will NOT result in the same tone change and deceleration characteristics.
Unfortunately, since it's a pre-1996 computer, I can't use tools like the scanguage to confirm full fuel cut but there is definitely some.
I have also found articles in the past where the 1987 Buick Turbo Regals (Grand National) had fuel-cut in their programming as well.
