08 Ford Escape not going into EV mode
Old Aug 7, 2020 | 07:27 PM
  #31
Default Re: 08 Ford Escape not going into EV mode
I've been servicing hybrid batteries for 4.5 years now and have replaced over 400 of those "relatively rare" failing batteries. I turn away a lot of business because I don't have the capacity to mass produce batteries or put out cheap garbage. I have direct data sources going back 3 years before I started and can document well over 2000 battery failures through only three one-man shop service providers alone. The big national boys are replacing 100s per month. When I return battery cores to the dealership, I see the half dozen batteries THEY'VE replaced IN THE LAST WEEK. They replace HUNDREDS per year. This is not from the "manufacturer" reporting to some moto-journalist. This is from the guy that orders batteries for inventory as they use them up. A little over a year ago, consumption was so high, they were down to 19 Gen2 batteries in the country, and dealers weren't given them up to others. Most of the country was out of stock for a few weeks because replacements were on a freighter from Japan.
I've talked to hundreds of people who just bought their 150K mile 2nd gen Prius only to need a battery a month, a week or even just a weekend after purchase.
I've owned 9 hybrids, and 100% of them had battery failures.
Working in the industry is a little different from reading about it.
Old Aug 8, 2020 | 05:03 PM
  #32
GatorJ's Avatar
Performance of vehicles as cabs is 90% not applicable to a consumer driven vehicle.
The average person drives their car 2-4 times per day. A round trip to work and another round trip somewhere. The average number of miles driven per year is around 15000.
In most cases, consumer cars get a full thermal cycle every drive, i.e., operating temp followed by a complete cool down.
A cab is driven/running almost constantly while in use. Even if turned off, it's for a very brief time.
A cab may see 10-15K miles per month.
Consumer vehicles experience about 10X the thermal cycles per mile driven than a vehicle operated as a cab. Those are two completely different operating environments.
If all you're looking at are things like wheel bearings and suspension components, then yes cab vehicle experience applies.
For things like a hybrid battery, in most cases, cab operation is more advantageous on a mileage basis - less thermal cycling of the pack (not sitting in the sun all day at work). Of all the Gen 3 Prius I've seen, most fail in the 120-150K mileage range. The one exception was a privately owned Discount Cab. 2015 model with 270K miles on it after 2 years. That battery was also in DRAMATICALLY better condition than ALL other packs including those that failed at under 100K miles.
Originally Posted by corski67
Well I don't think I could disagree more regarding the applicability of the cab example. I think I'll just end this now and say, I totally understand why you had to turn off your PM on this forum. You pretty much treat everyone here as though they are some inferior life form. Good luck with that.
Funny... I don't see any sources or data for your musings here at all but of course, you're right, I'm wrong.
Here's your data Mr. Know it all:
https://www.greencarreports.com/news...000-plus-miles
This author definitely disagrees with your assessment of Prius battery reliability and even includes the YouTube FEH taxi teardown:
https://www.thetruthaboutcars.com/20...5-years-later/
And... Even if your Prius Taxi battery DOES puke... It's really not that big of a deal in the grand scheme of things, although it is indeed relatively rare:https://www.forbes.com/sites/tonybra.../#581966d93ee9
https://www.consumerreports.org/hybr...o-hybrid-cars/
https://www.greencarreports.com/news...t-and-warranty
https://www.hybridcars.com/hybrid-car-battery/
https://hybridbatteryrepairservice.com/prius/
I could spend the next hour or two finding wonderful evidence that what I have stated is based in data and evidence... but of course I would still be wrong and you'd be right because that's what really matters here; that you must demonstrate to others how stupid they are and how smart you are. Thanks for the entertainment. Feel free to tell me how all this information isn't really representative of the point, blah, blah blah... YOU'RE RIGHT! Absolutely... So silly of me to even try to write something on the same page as someone as superior as you.
To the extent you are disagreeing with S Keith regarding the points he is making about hybrid taxi cabs, you are correct about one thing...you ARE wrong. Comparing a taxi cab HVTB that racked up a couple of hundred thousand miles over a few years to a normally driven vehicle that accumulates that kind of mileage over a decade plus ignores one of the major factors of rechargeable battery life, age, with the other being duty cycles. Factor in thermal loads and you're comparing apples to oranges in that sense.
Old Aug 10, 2020 | 03:50 PM
  #33
Hippo the Hybrid's Avatar
Hopefully, the lithium packs in newer EV's have a longer and more trouble-free service life or it doesn't look good for the "modern" world from a climate change perspective or the future of the single occupancy vehicle.
Old Aug 14, 2020 | 06:29 PM
  #34
hellapricefield's Avatar
I'll just drop in to chime on my FEH ex-taxi. Purchased from the original owner, on it's second transmission but still original traction battery and runs perfect.
Old Aug 14, 2020 | 07:49 PM
  #35
Do you have the detailed service records of what major components were replaced? Eg. PCM, Power Steering Torque Sensor, front end parts, etc. It might provide some predictive insights.
Old Aug 14, 2020 | 07:56 PM
  #36
Not many service records. According to the owner when I bought it, the only things it had needed replacing other than the trans and outside what would be considered "normal" maintenance (which I would assume includes front-end wear items such as control arms, sway bar links, etc) were the ABS module and two steering column shafts, both of which are supposedly known common issues. The (third) steering shaft that it's now on has a tiny bit of play, but not what I'd call concerning or warranting replacement just yet.
Old Aug 16, 2020 | 08:54 AM
  #37
Forgive me for asking in this thread, but what happens to the steering column shafts? Does the steering wheel start to wobble? What years are affected and what happens to them?
Old Aug 16, 2020 | 11:27 AM
  #38
We just had the steering torque sensor replaced on a 2010 FEH , 150,000km. Wife got into vehicle and the steering was very heavy, manual mode, with a dash display indicating a power steering fault. Vehicle not driveable and had to be towed to a mechanic. With diagnostic, part and installation, taxes, came to $CA1000. This is not a hybrid issue but a 2009-12 Ford Escape problem. Our vehicle had been recalled in 2015 and the vehicle software upgraded to provide a warning message and conversion to manual steering mode on startup if the computer system detected a fault while driving. Since no code was present when recalled, only the software was upgraded. If a fault was present, the recall would have replaced the torque sensor and I believe the steering column back then. This is apparently becoming a more common problem as the vehicles age. Ford won't help and there is apparently a class-action in the U.S. over this issue. Earlier in this story, Ford was replacing the steering column until the torque sensor was made available as a separate item to moderated the cost. That's about all I know at the moment except for the hole in my wallet. Keep your receipt in the event of another recall or successful class action.
Old Aug 16, 2020 | 02:02 PM
  #39
No worries. I believe the technical term is the "intermediate shaft". The U-joint develops play in it, so steering wheel starts to become more loose and develop a dead zone, a zone where you'll turn the wheel in either direction and nothing happens, and you have to turn it more than that dead zone before the car actually steers. Once it gets bad enough you end up having to constantly correct for the car drifting within the lane due to the dead zone, and basically look like those in-car green-screen scenes in TV shows where the car is clearly going straight but you can see the driver for some reason turning the wheel left and right constantly.
This is also not a hybrid-specific issue, my neighbor's 2010 V6 also had the same problem, and there are plenty of reports online about it occurring to 2nd gen escapes of all models. Such as shown in this video:
Old Aug 16, 2020 | 03:08 PM
  #40
In our case, I drove the vehicle a lot before it happened including a 500km round trip. I didn't detect anything out the ordinary except a bit of play, maybe, in the tie rods. It tracked true with almost zero correction on a straight road. What the computer didn't like came on suddenly with no prior warning. Restarting the vehicle didn't fix the issue although apparently when you clear the DTC it was working. In view of the complaints on line, it had to be fixed right away. Glad the sensor is now a separate part.
