06 Escape Hybrid starts for 2 sec and dies HELP🙏
Old Feb 23, 2026 | 11:28 AM
a06greenHybrid's Avatar
Talking 06 Escape Hybrid starts for 2 sec and dies HELP🙏
Hi all, looking for expert help diagnosing a no READY issue on a 2006 Ford Escape Hybrid.
I have no history on this vehicle other then it sat for months.
Symptoms:
  • Vehicle cranks, engine fires for about 1 second, then dies.
  • “Stop Safely Now” on the dash.
  • If I remove the correct HV interlock, it will not crank at all. Reinstalling it returns to the 1 second start then die behavior.
Tools:
  • Windows 10 laptop, FORScan v2.3.70, vLinker FS USB. Communication with modules is good.
DTCs (current):
  • BCM/Battery Control Module: P0A95-60
  • PCM: P1A10-FF
  • PCM: P1000-FF (expected)
  • GEM: B1218-20 and B106E-20 show as previously set, not present at time of request
HV battery data (Battery Control Module PIDs):
  • V_PACK: 344.21 V
  • BSOC: 0.00% ??? ( I charged it for 10hrs with a MeanWell 400V DC .5amp power supply)
  • TRAC_M_AMP: 0.00 A
  • DEL_MOD_V: 0.25 V
  • R_LEAKP and R_LEAKN: 999999 ohms
  • HEV_VEHSTAT shows “BPO” (battery power off)
    TESTS SO FAR:
I checked the HV fuse in the service disconnect and it is not blown, measured about 0.1 ohm.
I checked both FUEL cut out switches and all is well.
I MANUALLY charged the HBV with a MeanWell 400V DC .5amp charger for 10hours.
Brand new 12V battery.
Questions:
  1. With P0A95 present but HV fuse confirmed good and pack voltage present, what should I test next? Is this pointing to service disconnect plug sense circuit, contactor/precharge not completing, or a known software latch?
  2. Which exact BCM/TBCM PIDs should I log during a crank attempt (contactor command/status, precharge status, fuse sense, service disconnect status, etc.)?
  3. Any known pinpoint test steps for P0A95 on these that are most likely to catch the real failure?
Any guidance on the next highest yield checks would be appreciated. I can post logs/screenshots of live data during crank if you tell me which PIDs matter most.
Thanks!
Old Feb 25, 2026 | 09:03 AM
Default Re: 06 Escape Hybrid starts for 2 sec and dies HELP🙏
!!!!FIXED!!!! FIXED!!!! IF ANYONE HAS an early 2005-2006-maybe even early 2007 ESCAPE HIBRYD with code P0A95 READ THIS
SO after much research on the FORD ESCAPE HiBRYD with the P0A95 (HIGH Voltage Fuse) I found this TSB:
Hybrid System - Red Electrical Hazard Lamp/DTC P0A95 — 2006 Ford Escape 4WD L4-2.3L VIN H Hybrid Service Manual | Operation CHARM
Detailed repair manual for the 2006 Ford Escape 4WD L4-2.3L VIN H Hybrid.
charm.li
SB 06-25-6
12/01/06
RED ELECTRICAL HAZARD WARNING LAMP AND
DTC P0A95 - HYBRID VEHICLE
FORD:
2005-2006 Escape Hybrid
HOW I FIXED IT: I REFLASHED/FIRMWARE UPDATED/ the BCM or TBCM (BATTERY CONTROL MODULE)
HOW: win 10 laptop + Vlinker FS USB + FORScan BETA1.4(BETA ONLY = PAID VERSION FOR FORScan that has FIRMWARE UPDATES capability to reflash FORD MODULES). IT COSTS $20 for 1year license key + $30-$40 for Vlinker FS USB
Alternatively you need FORD IDS FACTORY PROGRAMER = LOTS OF $$$$ or you need to tow your car to FORD dealer and ask them to reflash/update the BCM/TBCM.
HERE IS THE BEFORE DATA FROM MY EARLY 2006 BCM FROM FORscan:
BCM-Battery Control Module
PART NUMBER: 7m64-10b687-ca
Calibration level: 7M64-10b687-ca
Strategy: 7m64-14c197-AB
THE UPDATE:
Strategy: 7m64-14c197-BD (NOTE it used to be AB version now it's BD after the update as of 2026, BUT it might be another "XX" calibration/strategy depending on when you do this or what part number the BCM is)
FORscan pulls the strategy/calibration from a server and it might differ BUT the point is you want whatever the latest ONE is available on the server at that time.
I did the firmware update to BCM/TBCM and car started up and drives PERFECT.
Michaela Scanlon
Jan 16, 2019 11:01 AM
grimbergen
Apr 25, 2016 03:30 PM
LeeS
Sep 1, 2011 03:44 AM
davisdesignsolutions
Oct 23, 2007 09:13 PM
