Website Questions & Input Suggestions and inquiries about Electric Vehicle Forums are welcome here.
Dynamic Mileage Forum Signatures
Old Aug 6, 2008 | 01:37 PM
  #161
robinhood's Avatar
Default Re: Dynamic Mileage Forum Signatures
test
Old Aug 22, 2008 | 07:51 PM
  #162
jmonti's Avatar
testing
Old Sep 3, 2008 | 02:02 PM
  #163
08MMHybridHappy's Avatar
Testing
Old Oct 17, 2008 | 12:27 PM
  #164
trekwars2000's Avatar
Testing the links in my tags below...
Old Apr 12, 2009 | 09:10 PM
  #165
thedutchtouch's Avatar
so i got it in my signature, but it still says 0 after 24 hrs. what gives, did i mess something up with the database? my car is https://www.greenhybrid.com/discuss/...ehicleid=19326 so my number should be 19326 no?
edit- my problem is that's my number in the database here, and i dont exist in the other (old) database?
Old May 5, 2009 | 04:04 PM
  #166
staze's Avatar
So, I can't seem to get my dynamic signature to work. It's been 24 hours, my vehicle ID is 15709, but no matter what, the mileage reads 0 MPG.
Thoughts?
Old May 5, 2009 | 06:01 PM
  #167
lyluvly's Avatar
I just follow the directions at: https://www.greenhybrid.com/discuss/...gnatures-1625/ and it works perfectly. Go over your steps carefully and try it again. good luck.
Old May 5, 2009 | 07:55 PM
  #168
staze's Avatar
I have done this. I have this code on my webpage as well, it doesn't show anything but 0 MPG.
It's really NOT that difficult, so the fact it doesn't work is kinda frustrating.
This should be my mileage: but as you can see, it's 0 MPG.
Old May 6, 2009 | 07:10 AM
  #169
ericbecky's Avatar
Contributor ($)
Staze, I found your car in the old interface, number 4113.
https://www.greenhybrid.com/compare/.../car/4113.html
You could use that number and that may get you your numbers back for now until IB corrects other parts of the database.
When I use my id# from the new database interface, my mpg goes to zero. If I use my id# from the old interface it works fine.
Old May 6, 2009 | 09:00 AM
  #170
staze's Avatar
Thanks a ton Eric! That did indeed fix the problem. I couldn't find a way to see the old DB.
Thanks!
