Website Questions & Input Suggestions and inquiries about Electric Vehicle Forums are welcome here.
Database v2 Bugs
Old Aug 18, 2005 | 08:07 PM
Schwa's Avatar
Default Database v2 Bugs
This is extremely minor, but I thought I would point it out for when the next work is done, otherwise I'll forget.
The metric style Aggregate Data Table reads the middle 50% as 8.71–7.11 but should properly be the other way around (7.11- 8.71). Also the metric temp is miscalculated, but I mentioned that elsewhere.
Old Aug 18, 2005 | 08:20 PM
lakedude's Avatar
Default Re: Database v2 Bugs
It isn't a bug but I miss the months in the graphs. Voltswagon showed a perfect cycle of how temperature affects mileage. It was lowest in winter, highest in spring and fall (no AC) and medium high in the hottest months of summer.
Old Aug 18, 2005 | 08:29 PM
Schwa's Avatar
I was going to suggest the ability to edit the 'share date' when you edit a tank, so that you don't have to enter in a date when you put a tank in (as is now) but you would be able to properly date a tank that you entered with a bunch of other tanks so that the monthly type graph could be plotted, perhaps as an option or secondary graph?
Old Aug 19, 2005 | 01:52 PM
Jason's Avatar
Site Founder
I'll take these into consideration with the next update. Thanks for your input.
haroldo
Jan 14, 2008 06:10 AM
Loonbeam
Oct 19, 2006 11:13 AM
Lilarienne
Sep 22, 2006 07:21 AM
