View Poll Results: What tire pressure do you run at?
35 / 33
16.22%
40 / 38
8.11%
42 / 40
18
48.65%
50 / 48
5.41%
Somthing else
21.62%
Voters: 37. You may not vote on this poll
Tire Pressure poll
Old Aug 28, 2006 | 04:13 PM
centrider's Avatar
Default Re: Tire Pressure poll
Originally Posted by kamsmart
How can I find a tire's recommended pressures by the manufacturer .. are these number ingrained into the rubber on the side of the tire? Specifically, I want to see why we arrived at the number of 42/40 for the Prius?
Also, my second car is a conventional Hyundai Sonata, and I am wondering what tire pressrue should I maintian in that car?
Hi,
The info I use is on the left door frame. That is where I get the 33, 35 psi (right, find 33 on an air gauge). So, I use a digital which I carry in my car. Still, I consider gauges suspect.
Anyway, it's the manufacture's suggestion. If I experience tire failure, I can honestly say I followed the rules.
Old Aug 28, 2006 | 07:33 PM
just522's Avatar
In our Prius I usually set the tires to something higher than 55 psi, but lower than 60. That makes for excellent, long glides. The Insight's tires are rarely less than 60 psi for the same reason. OEM tires on the Prius with 40,000 miles on them and remarkably even tread wear. I always lower the pressure a bit in winter for better traction, but no lower than 44/44.
haroldo
Mar 15, 2008 11:09 AM
haroldo
Jan 17, 2008 04:12 PM
Oiler
Jul 19, 2007 06:50 AM
milkandcheese
32
Jul 19, 2004 08:05 PM
