Storing a Prius--Effect on Battery
Old May 18, 2007 | 08:59 AM
Newbuyer's Avatar
Default Storing a Prius--Effect on Battery
Hi,
I am thinking of getting a Prius but have one concern. I will need to store the car in an unheated garage for 4-5 months every winter. During that time, the car won't be used or started at all. I am wondering what effect that will have on the battery. Has anyone done this?
Many thanks,
Newbuyer
Old May 18, 2007 | 09:02 AM
Delta Flyer's Avatar
Banned
Default Re: Storing a Prius--Effect on Battery
Partial answer: the trickle current the car radio, clock, etc needs will be from the 12-volt battery - the hybrid battery pack only propels the Prius.
How long does the Prius battery pack hold it's charge? Hope someone can help on that soon.
Old May 18, 2007 | 11:03 AM
Newbuyer's Avatar
thanks!!
Old May 18, 2007 | 10:47 PM
Patrick Wong's Avatar
Toyota TSB PG007-03 suggests that a stored Prius should be placed in "READY" mode for 30 minutes every two months to charge the hybrid system traction battery and the 12V auxiliary battery. In addition, when the Prius is stored for more than 10 days at a time, Toyota suggests that the 12V auxiliary battery be disconnected to prevent parasitic drain.
If the traction battery has discharged, it will be necessary to have your car towed to the dealer, and you will have to wait until the dealer can get hold of the special charger used to charge the traction battery. Apparently Toyota only has one of these chargers per sales region.
If you must leave your car unattended for 4-5 months in the winter, a Toyota hybrid is not the right choice for you.
Patrick Wong
Old May 19, 2007 | 10:45 AM
Newbuyer's Avatar
Thanks Patrick,
Your reply was really helpful. Much appreciated...
Old May 19, 2007 | 11:13 PM
owlmaster08's Avatar
My '07 HCH has a warning on the trunk to run it at least once a month, for at least half an hour, I think.
This is the nature of batteries, I'm afraid.
pauls
Jul 29, 2007 08:05 PM
MrBond
Dec 22, 2006 08:19 PM
belbe
Dec 4, 2006 09:49 AM
coyote
Mar 13, 2005 08:58 PM
