Seeming gas gauge inaccuracy
Old Feb 1, 2006 | 04:42 PM
wshepherd's Avatar
Default Re: Seeming gas gauge inaccuracy
I have a 2004 Prius, I bought it in Aug '04 and I have just under 20,000 miles. I had it in for the recall a few months ago and haven't had any other problems.
Old Feb 1, 2006 | 04:46 PM
PriusGuy04's Avatar
I was trying to figure out how much gas each bar stands for.... Hell I fill up when I hit the last bar,
Old Feb 1, 2006 | 06:50 PM
singingtiger's Avatar
After 24 tanks and 12,000 miles I have found a few consistent patterns but primarily each tank gauge varies due to the factors mentioned in other posts above. One gauge measure that has been the most consistent is the mileage I have at half tank--when five bars have been "used".
I am usually at 300 miles plus/minus 50 miles at half tank.
Old Feb 6, 2006 | 09:26 PM
JeromeP's Avatar
I'm inclined to believe that your experience is probably one-off. I'd see if another tank does the same thing.
If you gas up at the same place notice how each pump operates. If a pump filler valve is old or messed up in any way that can have a pretty significant effect on how well it fills up the Prius tank. Some pumps are very sensitive to back pressure, which most conventional tanks might not have much or. However I firmly believe that the bladder has a great deal more back pressure than a conventional tank and as such a sensitive pump will make filling difficult.
joekr
Jun 22, 2005 08:10 PM
DTDRIVER
May 23, 2005 04:26 PM
911Driver
Apr 21, 2005 08:46 PM
Jerry Nicholson
Feb 2, 2005 03:56 PM
Jason
Jan 12, 2005 07:10 PM
