Pump got stuck
Old Jan 14, 2004 | 04:54 PM
Patzee's Avatar
Jack:
BC - Isn't that British Columbia? If that's the case, then Washington State is directly south of you, on the West Coast. Confusion must be because I used the wrong word. It should have been *your* and not *you're*. :o
Pat
Old Jan 14, 2004 | 06:03 PM
JackC's Avatar
Originally posted by Patzee@Jan 14th 2004 @ 7:54 PM
Jack:
Pat
Patzee
Ah - I get it! I was referring to my Prius (this IS the Prius section, aftger all!) - A "BC" is a grouping of extras - you can read it "all of the above" - loaded, as it were.
So - A Seaside BC is the Prius with all possible options and a nice, sky-ish blue. Except I don't do colours.
Much as I would really like to actualy live in British Columbia... It is New York State in which I reside!
And you're right about your!
Jack
Old Jan 14, 2004 | 06:04 PM
Jason's Avatar
Site Founder
BC is another name for Prius package #9 with the works
Old Jan 14, 2004 | 09:55 PM
Patzee's Avatar
Old Jan 14, 2004 | 09:59 PM
Patzee's Avatar
Oh, another thing -- am I the only member who did not get the BC? We got everything but the Navigation, CD changer and Bluetooth.
Old Jan 16, 2004 | 05:40 AM
sgoncalo's Avatar
The gas inlet of the Prius is sized very tight to prevent gas vapors from excaping. There is a standard size for the nozzle on unleaded gas pumps. When unleaded gas was being phased in, the leaded gas pumps had the bigger nozzles that you could not accidently insert into the tank for an car that took unleaded only. With the standard size nozzle, the inlet of the Prius should not have any problems.
If some customer before you managed to drop the nozzle and bang it against the pavement, the tip of the nozzle may be bent slightly out of round. Most cars are more forgiving, but leak more gas vapor into the air as a result. Almost certainly, the pump out of spec, not your car.
tedson99
Jan 5, 2013 11:00 PM
IMAhybrid
Apr 16, 2008 03:36 PM
kris
Mar 5, 2007 05:15 AM
SilverToyCam
Jul 21, 2006 03:22 PM
jope
Jun 9, 2006 08:40 AM
