Prius II Transmission Losses
Old Dec 16, 2005 | 09:05 AM
EricGo's Avatar
Default Prius II Transmission Losses
Really nifty study carried out by ORNL to clarify how much energy is lost in the Prius II drivetrain/transmission.
I thought the following two graphs were the most informative (click on the images to see a magnified version. Note that the Y axis is watts wasted--
By component:
As oil Temperature Increases
Old Dec 18, 2005 | 08:32 AM
jmg14213
Guest
Posts: n/a
Default Re: Prius II Transmission Losses
I wonder how the IMA system compares for efficiency, especially with the CVT?
Old Dec 18, 2005 | 01:39 PM
bwilson4web's Avatar
Engineering first
Hi,
Answers for Honda hybrid hybrid performance questions are not often found in the Prius discussion group. Regardless, you could find the answer easily enough. The overall approach is:
1) Remove the engine (assumes a powered dynamo)
2) Make sure the Honda IMA motor shaft can rotate (you may need bearing support)
3) Make sure the lubrication pumps are connected or rig up a substitute
4) Make sure other fluid channels are sealed and setup substitute fluid loops
5) Connect the rear wheels to a dynometer (contact local hot rod shops)
Have the dynomo operator sweep different speeds and plot the Honda IMA power loss as a function of MPH. It is a good idea to rig up a lubricant heater and temperature probes to monitor the effects of temperatures. Also measure the generated EMF from the Honda IMA motor.
BTW, there is a Honda discussion group where IMA experts for Honda hybrids might be found.
GOOD LUCK!
Bob Wilson
twolostminds
Nov 17, 2014 06:23 AM
pkamm
Oct 11, 2010 11:11 AM
dg8200
Mar 10, 2009 12:33 AM
Jason
Mar 30, 2005 07:17 PM
jsanford
Jan 8, 2005 06:05 AM
