Prius 07 Purchased
Old Jul 18, 2007 | 05:56 PM
bear15's Avatar
Opec Nightmare
Talking Prius 07 Purchased
Hi everyone,
We just thought we would let you know that we recently purchased the touring edition of the 2007 prius which is requiring some repair-- it has less than 2k on it. We hope to have it fully repaired soon and add some tanks to the mileage log.
Old Jul 18, 2007 | 08:43 PM
bwilson4web's Avatar
Engineering first
Default Re: Prius 07 Purchased
Welcome to the club!
Originally Posted by bear15
Hi everyone,
So what sort of repairs?
Bob Wilson
Old Jul 18, 2007 | 09:10 PM
minerval's Avatar
Hybrid Newbie
Did you bump into the pole ? Or technical part failure ?
Stop the suspension, do tell....
Old Jul 21, 2007 | 05:29 AM
bear15's Avatar
Opec Nightmare
We have some damage on the left front corner (fender, strut, etc.). Also, we are not getting heat from the heater-- any suggestions? We will keep you updated.
Old Jul 21, 2007 | 06:07 AM
Engineering first
Wink Re: Prius 07 Purchased
Due to aerodynamic impacts, you'll need to get the front fixed or suffer an MPG hit at higher speeds. The 'strut', you mean MacPhearson strut? That can be a do it yourself job although you may need some tools from Sears. But I'm more concerned about potential damage to the steering linkages and wheel alignment. Are you doing the repairs or someone else?
You might consider going to PriusChat.com for their excellent maintenance and technical forums. Many well respected Prius technologists hang out there and if you post photos, you'll get a lot of helpful suggestions. Folks here are pretty good but we're more generalists.
The heater has an electric motor that pumps coolant through the heater coil. There should be a fuse that may need to be checked. Unfortunately the motor is located on my 03 Prius under the inverter. It isn't difficult to take the inverter off (or moved aside enough with its coolant hoses still attached.) But that would be the next step if you don't find a blown fuse in any of the fuse boxes.
My first recommendation is to get the maintenance manuals so you'll have a 'road map' to the systems and diagnostics. From Toyota, it'll run over $300 for the paper ones or you can subscribe to their technical service and try to download what you need. I've also seen paper manuals on Ebay from time to time. Your Prius is a model NHW20, 2004-current. Although having the exact model manual is best, many systems do not change that much between each model year.
GOOD LUCK!
Bob Wilson
Old Jul 21, 2007 | 12:05 PM
bear15's Avatar
Opec Nightmare
Bob-- Thanks a million!!!!
drewski
Aug 24, 2006 06:26 AM
ilene
Toyota Highlander Hybrid
Jul 30, 2005 11:21 AM
Hawflake
Jun 8, 2005 07:28 AM
sdhybrid
Introductions
May 31, 2005 11:33 AM
mikemc
Introductions
Dec 21, 2004 04:03 PM
