Priups - 1kW real world test
Old Dec 27, 2008 | 06:26 AM
  #31
bwilson4web's Avatar
Engineering first
Default Re: Priups - 1kW real world test
Originally Posted by wwest
I have a spare car battery that I keep fully charged (always on a multi-phase charger) that I brought in, hooked an 800 watt MSW inverter, and plugged the coffee pot into that. I maybe got two cups brewed before the "beep-beep-beep" of the inverter started up, I had to "re-seat" the battery (spring) clamps and maybe got another cup brewed before the battery was below the tolerance of the inverter, 10.5 volts.
If a full size 12 volt car battery with HIGH starting current capacity cannot provide ~800 watts (~60 amps), for the 5-10 minutes it takes to brew a pot of coffee just how long will the 12 volt "low" current capacity supply more than 10.5 volts.
Meanwhile your Prius was unused as a power source?
Bob Wilson
Old Dec 28, 2008 | 10:26 AM
  #32
wwest's Avatar
Yes, YES...!!
slajeune
Dec 14, 2005 11:08 AM
coyote
Sep 8, 2005 10:39 AM
Pravus Prime
Aug 20, 2005 02:02 PM
sherpadude
Dec 14, 2004 05:45 PM
