Old Prius battery experiences
Old Mar 6, 2008 | 01:41 AM
bwilson4web's Avatar
Engineering first
Wink Re: Old Prius battery experiences
Hi Andy,
Originally Posted by fuji
Great work on the battery refurbishing.
Any progress on the failure analysis of the failed battery?
Once I figured out that 04024 (SN: 03XBHB04024C) was not going to recover and seeing the wild voltage changes, I decided to use it for mechanical analysis and testing. That is why I cut off the top, to see the interior.
Later, I picked up some of the electrode fragments:
At the top you can see how the metal hydride electrode has a thin, mesh that covers it to keep it separated from the nickel hydroxide electrode. There is another example at the bottom where the metal hydride has slipped out of the separator. The patents describe this as a plastic material.
I suspect that as the water leaves the cell, the active area of the cell electrodes decreases. Meanwhile, the electrical loads do not. This leads to ohmic and some chemical heating in that smaller area with higher, spot temperatures. Eventually, the separator material gets so hot that it melts and no longer keeps the electrodes separated . . . a shorted cell. This can not be repaired.
My thinking is the best way to avoid this failure mode is to keep the cells well hydrated so the maximum area is working. This avoids a local hot-spot that fails the cell. It is also why I suspect that as long as a cell has not shorted, re-hydration not only restores them to service but significantly extends their life.
Bob Wilson
ps. If there were a fiber separator with very high temperature resistance, eventually all of the water would leave the cell and it would be inert. However, adding water would restore full capability.
Old Mar 8, 2008 | 02:02 AM
fuji's Avatar
Default Re: Old Prius battery experiences
Thanks again Bob,
I would agree with your explanation.
So the failed cells had no electrolye solution left whatsoever? Or enough of the separator was exposed that it was not cooled. The poor efficiency of the used cells 30-60% shows that there is a non-conductive/high resistance film present on the electrodes which will heat the electrolyte solution leading to water blow off from the pressure release valves. Keeping the electrolyte topped up should prevent a "hard" failure. I think you would still need periodic reconditioning/restore by the method you showed to extend the life of the battery.
Great work
Andrew
Old Mar 8, 2008 | 05:28 AM
Engineering first
Thanks again Bob,
So the failed cells had no electrolyte solution left whatsoever? Or enough of the separator was exposed that it was not cooled.
The latter is the case. We're seeing current flows of 50-75 amps through the NHW11 batteries. As the electrolyte 'dries out', the area this current flows through becomes smaller and smaller, eventually forming point resistors that get hot enough to melt the plastic film separators. At that point the cell shorts and is unrecoverable. It has to be disassembled and rebuilt with a new separator.
. . . The poor efficiency of the used cells 30-60% shows that there is a non-conductive/high resistance film . . .
It is the reduced area as the electrolyte 'dries out'. It really isn't drying in the conventional sense but rather the inevitable electrolysis to H_{2} and especially O_{2}.
. . . present on the electrodes which will heat the electrolyte solution leading to water blow off from the pressure release valves. Keeping the electrolyte topped up should prevent a "hard" failure. I think you would still need periodic reconditioning/restore by the method you showed to extend the life of the battery. . . .
After the KOH electrolyte loses the hydrogen and oxygen, you have potassium left behind. Adding distilled water works because it forms KOH and releases H_{2} that out-gasses afterwards. I'm planning to measure how much to get an idea of the quantities involved. But also, there is something called electrode 'activation' that occurs during NiMH manufacture.
I don't have enough information about electrode activation but I suspect there is a layer of gas, probably oxygen, on the surface that has to be 'purged' so the KOH can reach the metal hydride. This layer would prevent the hydrogen molecules being absorbed into the hydride matrix. I suspect electrode activation applies enough charge to displace and/or generate enough hydrogen to convert the surface oxygen into hydride ions.
I am not convenced that battery reconditioning, the use of a .1C or lower charge, is as effective as claimed. The reason is I have some AA NiMH batteries that had excellent capacity, 2,000 mAhr, that after using in my digital camera now show barely 800 mAhr. I suspect excessive currents have led to premature, out-gassing and loss of capacity. Over in Prius Technical Stuff, I'm planning to do the test as well as putting in some probes to measure individual cell characteristics.
Bob Wilson
infael
Oct 24, 2012 05:36 AM
Atomic Frog
Mar 8, 2006 07:51 AM
tom.arthur
Feb 9, 2006 02:30 PM
matson29
Nov 5, 2004 12:06 PM
vxmike
Aug 30, 2004 12:55 AM
