maintenance required
Old Jan 23, 2007 | 11:06 AM
ourius's Avatar
Default maintenance required
At 5000 miles the maint. req. light came on. I've heard that this had happened on other Prius cars. Any experience?
Old Jan 23, 2007 | 11:08 AM
bwilson4web's Avatar
Engineering first
Default Re: maintenance required
The NHW20 Prius has a reminder feature for getting the oil changed. It sounds like you've hit that mark.
I don't have the instructions handy but if you search the web and messages, I think you'll find how to turn it off.
Bob Wilson
Old Jan 23, 2007 | 01:52 PM
ag4ever's Avatar
Dazed and Confused
If it is like the TCH, you set the trip screen to trip a, then turn the car off. Then while holding down the reset button, you turn the car back on. It will reset the maintenance interval, but also resets the trip A.
And it indicates when you need oil changes. It starts indicating "maintenance required soon" at about 4500 miles.
Old Jan 23, 2007 | 02:42 PM
Engineering first
Is this found in the owner's manual?
Bob Wilson
Old Jan 23, 2007 | 03:36 PM
bparsons's Avatar
Banned
Is this something the dealer should do after an oil change?
Old Jan 23, 2007 | 05:05 PM
Engineering first
Yes. Of course all bets are off for the quickie lube places.
Bob Wilson
Old Jan 23, 2007 | 07:12 PM
msantos's Avatar
Eco Accelerometrist
hummm... Not that I am close to that figure, but isn't 4500 miles too low a figure to trigger the reminder? I confess I did not research this prior to buying my 2007, but I expected a much higher mileage between oil changes.
Oh, well...
On a second thought, does the Prius actually evaluate operating conditions as inputs to the "maintenance warning" notice?
Cheers;
MSantos
Old Jan 23, 2007 | 08:21 PM
ag4ever's Avatar
Dazed and Confused
Keep in mind this is for the TCH, but the mileage minder is only a mileage based indicator, and not an engine load based indicator such as is found in some GM vehicles.
I don't think the reset procedure is in the manual, nor is the mileage the maintenance minders are triggered. I am at approximatly 4,000 miles on my current oil change, and should trip the first level of the maintenance minder this weekend or early next week. I will keep an eye on it.
Since I am running full synthetic, I would like my oil change intervals to be 7500 to 10,000 miles, but unitl I hit 36,000 miles I will do as Toyota recomends. On less thing to fight about if there is a warranty issue.
Old Jan 24, 2007 | 01:32 AM
bparsons's Avatar
Banned
Bob Wilson
Old Jan 24, 2007 | 06:09 AM
FireEngineer's Avatar
Reminder lamp comes on when you first start the car between 4,500 and 5,000 miles. After 5,000 miles it stays on constantly. To reset make sure your odometer is on total miles, NOT trip A or trip B, turn off car, hold down odometer button, start car in ready mode (brake depressed, press start button), the odometer reading will show a series of dashes, when all 5 dashes are gone release button and it's reset.
Wayne
