Laptop
Old May 5, 2005 | 07:32 AM
infael's Avatar
Default Laptop
This Saturday, I haveta make a 19 hour roundtrip from CO to OK. I plan to bring my laptop to do some homework and watch a couple dvd movies. I plan to plug it in the the electric socket.
Is there anything I need to know about doing this?
TIA
infael
Old May 5, 2005 | 09:44 AM
Jason's Avatar
Site Founder
Default Re: Laptop
You mean as far as drawing power from the outlet? Nothing that I know of. Works like any other car
Old May 5, 2005 | 11:38 AM
infael's Avatar
Default Re: Laptop
Thanks!
Old May 5, 2005 | 05:01 PM
JeromeP's Avatar
Default Re: Laptop
The Prius does shut off the 12v sockets when the car is not in ready or Ig-on mode. So, don't expect power to come from the vehicle when it is not running, however when running you should have plenty of 12v power. I've read that when the vehicle is in Ready mode that the output from the sockets is closer to 14v. That shouldn't have any negative effect on your 12v devices. However if you have the mod from Costal which forces that dash 12v to be on all the time the output when the vehicle is not in Ready is closer to 11v.
Old May 10, 2005 | 11:00 AM
Sergepopper's Avatar
Default Re: Laptop
Or you can get an easy fix from Coastal which, when installed keeps the forward lighter socket on all the time. Coastal http://www.coastaletech.com/04prius.htm
Old May 12, 2005 | 03:27 PM
gschoen's Avatar
Default Re: Laptop
You can also get an accessory adapter with battery clips you can hook directly to your battery for any always on outlet in your cargo area. I got one for $3 at Pep Boys, make sure to use with fused devices only (the adapter I bought didn't have a fuse).
rrrrrroger
Off Topic
Feb 17, 2008 11:53 PM
highflyer_i469
Aug 11, 2007 09:00 PM
psyshack
Apr 11, 2006 01:42 PM
Atomic Frog
Off Topic
Oct 3, 2005 02:51 PM
